ESP32 Feather V2 Batt Monitor wrong voltage
by djoob on Mon Jul 04, 2022 12:25 am
I must have my math wrong. I cannot figure out how to read the battery voltage on the ESP32 Feather V2 board.
#define BAT_MON 35
float measuredvbat = 0;
  Serial.begin(115200);
  pinMode(BAT_MON, INPUT);
  measuredvbat = analogRead(BAT_MON);
  measuredvbat *= 2;    // we divided by 2, so multiply back
  measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
  measuredvbat /= 4096; // convert to voltage
  Serial.print("VBat: " );
  Serial.println(measuredvbat);
  delay(1000);
Serial output says. VBat: 3.84 however a multimeter shows the battery voltage is 4.2v
The schematic shows a voltage divider that should divide the voltage in half.
I've tried several variations found online with no luck getting the correct voltage.
djoob
Re: ESP32 Feather V2 Batt Monitor wrong voltage
by adafruit_support_mike on Tue Jul 05, 2022 9:27 pm
The code looks right. What output are you getting?
by djoob on Tue Jul 05, 2022 9:40 pm
Serial output says:
VBat: 3.84
However, a multimeter shows the battery voltage is 4.2v
djoob
by adafruit_support_mike on Wed Jul 06, 2022 5:45 pm
There we go..
The ESP32's ADC has a 3.6V reference. Try using that value instead of 3.3V:
  measuredvbat *= 3.6;  // Multiply by 3.6V, our reference voltage
by djoob on Wed Jul 06, 2022 6:05 pm
AH. Thank you!
djoob
