Metro Mini 328 5V Programming
Post Reply
BDL
Post by BDL »
What do I need to do to program the device? Can't seem to get it to program blink. Item 2590.
Device name? Is it "Adafruit Feather 328p"? Something else? Nothing obviously matches.
Which programmer? USBtinyISP? Something else? None of the ones I tried seem to connect
The message I am getting is:
Arduino: 1.8.19 (Linux), TD: 1.57, Board: "Adafruit Feather 328P"
Sketch uses 936 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/home/bruce/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/bruce/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/tmp/arduino_build_947207/Blink_328.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/bruce/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
         User configuration file is "/home/bruce/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : arduino
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf8
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfa
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf8
avrdude done.  Thank you.
An error occurred while uploading the sketch
There is no setup info on the product page, nor links to one. This is unlike say the M4 Feather Express, which I am familiar with.
Do I need to setup drivers for this? Currently connected as /dev/USB0
When I ask for board info I get
BN: Unknown board
VID: 10C4
PID: EA60
SN: Upload any sketch to obtain it
Thanks. Any guides or pointers would be helpful.
BDL
Re: Metro Mini 328 5V Programming
Post by BDL »
The board name was wrong.
This device is "Adafruit Metro", or at least it will program as that.
Used the USBtinyISP programmer.
It would be helpful to know the board name on the product page.
The markings on the board say Metro Mini. The product tag says Metro Mini. The device is a 328.
argonblue
Post by argonblue »
The tutorial page is at https://learn.adafruit.com/adafruit-metro-mini but it doesn't seem to be linked from the product page, for some reason. It says to select "Arduino UNO" as the board type.
BDL
Post by BDL »
Seems odd. The product page should link to that page.
Upon rereading the product page it does say to use UNO as the board, so I guess that is sufficient. I must have missed that the first time around.
Post Reply
