Feather 0x0b for LC70903F shows in scan but can't be used
jonjlaw
Post by jonjlaw »
I'm trying to get battery reporting working on my Adafruit ESP32-S3 Feather with 4MB Flash 2MB PSRAM - STEMMA QT / Qwiic - https://www.adafruit.com/product/5477
I was following the code in the example found here: https://learn.adafruit.com/adafruit-esp ... ry-3122383
But have added some code from the i2c page to prove that the address is listed in a scan: https://learn.adafruit.com/scanning-i2c ... cuitpython
The code I am currently running:
import time
import board
from adafruit_lc709203f import LC709203F
i2c = board.I2C()
while not i2c.try_lock():
    pass
try:
    print(
        "I2C addresses found:",
        [hex(device_address) for device_address in i2c.scan()],
finally:  # unlock the i2c bus when ctrl-c'ing out of the loop
    i2c.unlock()
time.sleep(1)
sensor = LC709203F(board.I2C())
print("IC version:", hex(sensor.ic_version))
while True:
    print(
        "Battery: %0.3f Volts / %0.1f %%" % (sensor.cell_voltage, sensor.cell_percent)
    time.sleep(1)
I am getting the output below:
I2C addresses found: ['0xb']
  File "code.py", line 20, in <module>
  File "adafruit_lc709203f.py", line 117, in __init__
ValueError: No I2C device at address: 0xb
Code done running.
I have also seen this message:
  File "adafruit_lc709203f.py", line 122, in __init__
  File "adafruit_lc709203f.py", line 126, in init_RSOC
  File "adafruit_lc709203f.py", line 247, in _write_word
OSError: [Errno 116] ETIMEDOUT
dastels
Re: Feather 0x0b for LC70903F shows in scan but can't be use
Post by dastels »
Have you tried it without the scan code?
jonjlaw
Post by jonjlaw »
Yes, I only added the scan code after it failed without it. I wanted to see if 0xb was listed.
dastels
Post by dastels »
How do you have the LC70903F connected to the Feather?
jonjlaw
Post by jonjlaw »
It is part of the board.
dastels
Post by dastels »
Doah. I'm used to the breakout.
Have you tried the C++ example? If that fails as well then it's most likely the LC70903F that's at fault.
adafruit2
Post by adafruit2 »
S3 has a bug right now in i2c in ESP-DIF
https://github.com/adafruit/circuitpython/issues/6311
its in progress! you can subscribe to be notified when its fixed 'upstream'
