FEATHER 32u4 w RFM69HCW -difficulty w/ serial connection
by sketchy on Sun Jul 24, 2016 4:12 pm
My challenge is the serial port the Feather is connected via USB shows up sporadically (mostly it doesn't but every once in awhile it does). Under Tools/Port. When it doesn't, I do what it says to do within the manual bootloading section of the docs: https://learn.adafruit.com/adafruit-fea ... ootloading
OK...manually bootloading does upload the code. BUT now the serial monitor can't be opened. When trying to, I am told the port can't be found.
When the serial port does show, the upload works, and I can open the serial monitor, I cannot get anything to print within setup(). On some sketches, printing within the loop() works. Sometimes not.
My OSX = 10.10.5
Is there a known challenge (besides the strong likelihood I am not bumbling around correctly?)?
Thank you.
sketchy
Re: FEATHER 32u4 w RFM69HCW -difficulty w/ serial connection
by adafruit_support_mike on Wed Jul 27, 2016 11:40 pm
Give it a few seconds between uploading new firmware and trying to open the Serial Monitor. The ATmega32u4 has to shut down the bootloader's USB connection and register a new one, and that takes a while.
by sketchy on Thu Jul 28, 2016 8:31 am
THanks. That certainly made connecting to the serial monitor more repeatable. The challenge continues to be the serial monitor does not handle prints within setup...that is more an inconvenience than a show stopper.
Again, thank you for your reply.
sketchy
by adafruit_support_mike on Thu Jul 28, 2016 8:33 pm
Are you using:
while ( ! Serial ) { delay( 10 ); }
before you call Serial.begin()?
That will make the code wait until the USB registration has finished before trying to print anything.
by sketchy on Fri Jul 29, 2016 6:32 am
YIPPEE!!! I had not had this line in my code. I TRULY appreciate the explanation and not just the fix. It makes sense to me what is going on. Having a grasp of the difference with the ATmega32m4's boot behavior versus chip in Arduino soothes my mind. I wonder if the Blink example is the best one to highlight when discussing using the Arduino IDE in the docs... Rather, perhaps a template..
anywho, Thank you very much. Please find many things to smile about.
sketchy
