Polling Rotary Encoder on 32u4
by wb8nbs on Fri May 19, 2017 4:20 pm
Tried for about a day and a half to debounce a product 377 rotary encoder connected to a Feather. I finally found an example that uses a Gray code technique and works perfectly. It depended on using bits 0 and 1 of a port register though so for the Feather I had to modify slightly, the attached version uses bits 6 and 7 of port F on the 32u4 (Feather digital 18 and 19). The original example is at https://www.circuitsathome.com/mcu/read ... n-arduino/. Hope this helps someone.
RotaryEncPoll2.zip
Example sketch for debounced rotary encoder
(917 Bytes) Downloaded 41 times
wb8nbs
Re: Polling Rotary Encoder on 32u4
by adafruit_support_mike on Sat May 20, 2017 4:36 am
That's very interesting.. I wouldn't have though to read an encoder in terms of Gray code, but it makes perfect sense now that I've seen it.
Thanks for posting the link!
by adafruit_support_bill on Sat May 20, 2017 6:09 am
Very clever approach! Thanks for posting it.
by wb8nbs on Sun May 21, 2017 10:23 pm
Oleg Mazurov also has a detailed post describing the same method but implemented with an interrupt routine. I couldn't use this because I already hacksawed off the end of the Feather that has the interrupt pins. https://www.circuitsathome.com/mcu/rotary-encoder-interrupt-service-routine-for-avr-micros/
wb8nbs
by vibur on Sat Aug 05, 2017 2:45 pm
When I looked at this, I was getting four results with every turn of the encoder. How do you typically compensate for that? Sticking a /4 in various positions around the volume increment wasn't working for me.
vibur
by wb8nbs on Sat Aug 05, 2017 7:13 pm
vibur wrote:When I looked at this, I was getting four results with every turn of the encoder. How do you typically compensate for that? Sticking a /4 in various positions around the volume increment wasn't working for me.
The function only returns +1 , -1 or zero. You can scale the result (volume) by dividing it by four.
wb8nbs
by wb8nbs on Sat Dec 30, 2017 4:33 pm
The Adafruit rotary encoder generates four state changes per detent click. This is a problem if you're using it to change something exactly one step at a time. If your sketch has this trouble and you're using the gray code method above, try using this lookup table
static int8_t enc_states[] = {0, 0, 1, 0, 0, 0, 0, 0, -1, 0, 0, 0, 0, 0, 0, 0};
which allows only one state change per detent. Also disallows the state changes immediately adjacent to the detent which greatly reduces glitching when you touch the knob. HTH.
wb8nbs
