Here is the entire library... If ya had any thoughts. Hooked things up to a scope and it is dead....
@file Adafruit_RA8875.cpp
@author Limor Friend/Ladyada, K.Townsend/KTOWN for Adafruit Industries
@license BSD license, all text above and below must be included in
any redistribution
This is the library for the Adafruit RA8875 Driver board for TFT displays
---------------> http://www.adafruit.com/products/1590
The RA8875 is a TFT driver for up to 800x480 dotclock'd displays
It is tested to work with displays in the Adafruit shop. Other displays
may need timing adjustments and are not guanteed to work.
Adafruit invests time and resources providing this open
source code, please support Adafruit and open-source hardware
by purchasing products from Adafruit!
BSD license, check license.txt for more information.
All text above must be included in any redistribution.
@section HISTORY
v1.0 - First release
v1.1 - Changed to use SERCOMM 1 for M0 Feather
#include <SPI.h>
#include "Adafruit_RA8875.h"
#include "wiring_private.h" // pinPeripheral() function
SPIClass mySPI (&sercom1, 12, 13, 11, SPI_PAD_0_SCK_1, SERCOM_RX_PAD_3);
Constructor for a new RA8875 instance
@args CS[in] Location of the SPI chip select pin
@args RST[in] Location of the reset pin
Adafruit_RA8875::Adafruit_RA8875(uint8_t CS, uint8_t RST) : Adafruit_GFX(800, 480) {
_cs = CS;
_rst = RST;
Initializes the LCD driver and any HW required by the display
@args s[in] The display size, which can be either:
'RA8875_480x272' (4.3" displays) r
'RA8875_800x480' (5" and 7" displays)
boolean Adafruit_RA8875::begin(enum RA8875sizes s) {
_size = s;
if (_size == RA8875_480x272) {
_width = 480;
_height = 272;
if (_size == RA8875_800x480) {
_width = 800;
_height = 480;
pinMode(_cs, OUTPUT);
digitalWrite(_cs, HIGH);
pinMode(_rst, OUTPUT);
digitalWrite(_rst, LOW);
delay(100);
digitalWrite(_rst, HIGH);
delay(100);
mySPI.begin();
// Assign pins 11, 12, 13 to SERCOM functionality
pinPeripheral(11, PIO_SERCOM);
pinPeripheral(12, PIO_SERCOM);
pinPeripheral(13, PIO_SERCOM);
#ifdef __AVR__
mySPI.setClockDivider(SPI_CLOCK_DIV128);
mySPI.setDataMode(SPI_MODE0);
#endif
if (readReg(0) != 0x75) {
return false;
initialize();
#ifdef __AVR__
mySPI.setClockDivider(SPI_CLOCK_DIV4);
#endif
return true;
/************************* Initialization *********************************/
Performs a SW-based reset of the RA8875
void Adafruit_RA8875::softReset(void) {
writeCommand(RA8875_PWRR);
writeData(RA8875_PWRR_SOFTRESET);
writeData(RA8875_PWRR_NORMAL);
delay(1);
Initialise the PLL
void Adafruit_RA8875::PLLinit(void) {
writeReg(RA8875_PLLC1, RA8875_PLLC1_PLLDIV1 + 10);
delay(1);
writeReg(RA8875_PLLC2, RA8875_PLLC2_DIV4);
delay(1);
delay(1);
delay(1);
Initialises the driver IC (clock setup, etc.)
void Adafruit_RA8875::initialize(void) {
PLLinit();
writeReg(RA8875_SYSR, RA8875_SYSR_16BPP | RA8875_SYSR_MCU8);
/* Timing values */
uint8_t pixclk;
uint8_t hsync_start;
uint8_t hsync_pw;
uint8_t hsync_finetune;
uint8_t hsync_nondisp;
uint8_t vsync_pw;
uint16_t vsync_nondisp;
uint16_t vsync_start;
/* Set the correct values for the display being used */
pixclk = RA8875_PCSR_PDATL | RA8875_PCSR_4CLK;
hsync_nondisp = 10;
hsync_start = 8;
hsync_pw = 48;
hsync_finetune = 0;
vsync_nondisp = 3;
vsync_start = 8;
vsync_pw = 10;
else if (_size == RA8875_800x480)
pixclk = RA8875_PCSR_PDATL | RA8875_PCSR_2CLK;
hsync_nondisp = 26;
hsync_start = 32;
hsync_pw = 96;
hsync_finetune = 0;
vsync_nondisp = 32;
vsync_start = 23;
vsync_pw = 2;
writeReg(RA8875_PCSR, pixclk);
delay(1);
/* Horizontal settings registers */
writeReg(RA8875_HDWR, (_width / 8) - 1); // H width: (HDWR + 1) * 8 = 480
writeReg(RA8875_HNDFTR, RA8875_HNDFTR_DE_HIGH + hsync_finetune);
writeReg(RA8875_HNDR, (hsync_nondisp - hsync_finetune - 2)/8); // H non-display: HNDR * 8 + HNDFTR + 2 = 10
writeReg(RA8875_HSTR, hsync_start/8 - 1); // Hsync start: (HSTR + 1)*8
writeReg(RA8875_HPWR, RA8875_HPWR_LOW + (hsync_pw/8 - 1)); // HSync pulse width = (HPWR+1) * 8
/* Vertical settings registers */
writeReg(RA8875_VDHR0, (uint16_t)(_height - 1) & 0xFF);
writeReg(RA8875_VDHR1, (uint16_t)(_height - 1) >> 8);
writeReg(RA8875_VNDR0, vsync_nondisp-1); // V non-display period = VNDR + 1
writeReg(RA8875_VNDR1, vsync_nondisp >> 8);
writeReg(RA8875_VSTR0, vsync_start-1); // Vsync start position = VSTR + 1
writeReg(RA8875_VSTR1, vsync_start >> 8);
writeReg(RA8875_VPWR, RA8875_VPWR_LOW + vsync_pw - 1); // Vsync pulse width = VPWR + 1
/* Set active window X */
writeReg(RA8875_HSAW0, 0); // horizontal start point
writeReg(RA8875_HSAW1, 0);
writeReg(RA8875_HEAW0, (uint16_t)(_width - 1) & 0xFF); // horizontal end point
writeReg(RA8875_HEAW1, (uint16_t)(_width - 1) >> 8);
/* Set active window Y */
writeReg(RA8875_VSAW0, 0); // vertical start point
writeReg(RA8875_VSAW1, 0);
writeReg(RA8875_VEAW0, (uint16_t)(_height - 1) & 0xFF); // horizontal end point
writeReg(RA8875_VEAW1, (uint16_t)(_height - 1) >> 8);
/* ToDo: Setup touch panel? */
/* Clear the entire window */
writeReg(RA8875_MCLR, RA8875_MCLR_START | RA8875_MCLR_FULL);
delay(500);
Returns the display width in pixels
@returns The 1-based display width in pixels
uint16_t Adafruit_RA8875::width(void) { return _width; }
Returns the display height in pixels
@returns The 1-based display height in pixels
uint16_t Adafruit_RA8875::height(void) { return _height; }
/************************* Text Mode ***********************************/
Sets the display in text mode (as opposed to graphics mode)
void Adafruit_RA8875::textMode(void)
/* Set text mode */
writeCommand(RA8875_MWCR0);
uint8_t temp = readData();
temp |= RA8875_MWCR0_TXTMODE; // Set bit 7
writeData(temp);
/* Select the internal (ROM) font */
writeCommand(0x21);
temp = readData();
temp &= ~((1<<7) | (1<<5)); // Clear bits 7 and 5
writeData(temp);
@args x[in] The x position of the cursor (in pixels, 0..1023)
@args y[in] The y position of the cursor (in pixels, 0..511)
void Adafruit_RA8875::textSetCursor(uint16_t x, uint16_t y)
/* Set cursor location */
writeCommand(0x2A);
writeData(x & 0xFF);
writeCommand(0x2B);
writeData(x >> 8);
writeCommand(0x2C);
writeData(y & 0xFF);
writeCommand(0x2D);
writeData(y >> 8);
Sets the fore and background color when rendering text
@args foreColor[in] The RGB565 color to use when rendering the text
@args bgColor[in] The RGB565 colot to use for the background
void Adafruit_RA8875::textColor(uint16_t foreColor, uint16_t bgColor)
/* Set Fore Color */
writeCommand(0x63);
writeData((foreColor & 0xf800) >> 11);
writeCommand(0x64);
writeData((foreColor & 0x07e0) >> 5);
writeCommand(0x65);
writeData((foreColor & 0x001f));
/* Set Background Color */
writeCommand(0x60);
writeData((bgColor & 0xf800) >> 11);
writeCommand(0x61);
writeData((bgColor & 0x07e0) >> 5);
writeCommand(0x62);
writeData((bgColor & 0x001f));
/* Clear transparency flag */
writeCommand(0x22);
temp &= ~(1<<6); // Clear bit 6
writeData(temp);
Sets the fore color when rendering text with a transparent bg
void Adafruit_RA8875::textTransparent(uint16_t foreColor)
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Set transparency flag */
writeCommand(0x22);
temp |= (1<<6); // Set bit 6
writeData(temp);
Sets the text enlarge settings, using one of the following values:
0 = 1x zoom
1 = 2x zoom
2 = 3x zoom
3 = 4x zoom
@args scale[in] The zoom factor (0..3 for 1-4x zoom)
void Adafruit_RA8875::textEnlarge(uint8_t scale)
if (scale > 3) scale = 3;
/* Set font size flags */
writeCommand(0x22);
temp &= ~(0xF); // Clears bits 0..3
temp |= scale << 2;
temp |= scale;
writeData(temp);
_textScale = scale;
Renders some text on the screen when in text mode
@args buffer[in] The buffer containing the characters to render
@args len[in] The size of the buffer in bytes
void Adafruit_RA8875::textWrite(const char* buffer, uint16_t len)
if (len == 0) len = strlen(buffer);
writeCommand(RA8875_MRWC);
for (uint16_t i=0;i<len;i++)
writeData(buffer[i]);
#if defined(__AVR__)
if (_textScale > 1) delay(1);
#elif defined(__arm__)
// This delay is needed with textEnlarge(1) because
// Teensy 3.X is much faster than Arduino Uno
if (_textScale > 0) delay(1);
#endif
/************************* Graphics ***********************************/
Sets the display in graphics mode (as opposed to text mode)
void Adafruit_RA8875::graphicsMode(void) {
temp &= ~RA8875_MWCR0_TXTMODE; // bit #7
writeData(temp);
Waits for screen to finish by polling the status!
boolean Adafruit_RA8875::waitPoll(uint8_t regname, uint8_t waitflag) {
/* Wait for the command to finish */
while (1)
uint8_t temp = readReg(regname);
if (!(temp & waitflag))
return true;
return false; // MEMEFIX: yeah i know, unreached! - add timeout?
Sets the current X/Y position on the display before drawing
@args x[in] The 0-based x location
@args y[in] The 0-base y location
void Adafruit_RA8875::setXY(uint16_t x, uint16_t y) {
writeReg(RA8875_CURH0, x);
writeReg(RA8875_CURH1, x >> 8);
writeReg(RA8875_CURV0, y);
writeReg(RA8875_CURV1, y >> 8);
HW accelerated function to push a chunk of raw pixel data
@args num[in] The number of pixels to push
@args p[in] The pixel color to use
void Adafruit_RA8875::pushPixels(uint32_t num, uint16_t p) {
digitalWrite(_cs, LOW);
mySPI.transfer(RA8875_DATAWRITE);
while (num--) {
mySPI.transfer(p >> 8);
mySPI.transfer(p);
void Adafruit_RA8875::fillRect(void) {
writeCommand(RA8875_DCR);
writeData(RA8875_DCR_LINESQUTRI_STOP | RA8875_DCR_DRAWSQUARE);
writeData(RA8875_DCR_LINESQUTRI_START | RA8875_DCR_FILL | RA8875_DCR_DRAWSQUARE);
Draws a single pixel at the specified location
@args color[in] The RGB565 color to use when drawing the pixel
void Adafruit_RA8875::drawPixel(int16_t x, int16_t y, uint16_t color)
mySPI.transfer(color >> 8);
mySPI.transfer(color);
Draws a HW accelerated line on the display
@args x0[in] The 0-based starting x location
@args y0[in] The 0-base starting y location
@args x1[in] The 0-based ending x location
@args y1[in] The 0-base ending y location
void Adafruit_RA8875::drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color)
/* Set X */
writeCommand(0x91);
writeData(x0);
writeCommand(0x92);
writeData(x0 >> 8);
/* Set Y */
writeCommand(0x93);
writeData(y0);
writeCommand(0x94);
writeData(y0 >> 8);
/* Set X1 */
writeCommand(0x95);
writeData(x1);
writeCommand(0x96);
writeData((x1) >> 8);
/* Set Y1 */
writeCommand(0x97);
writeData(y1);
writeCommand(0x98);
writeData((y1) >> 8);
/* Set Color */
writeCommand(0x63);
writeData((color & 0xf800) >> 11);
writeCommand(0x64);
writeData((color & 0x07e0) >> 5);
writeCommand(0x65);
writeData((color & 0x001f));
/* Draw! */
writeData(0x80);
waitPoll(RA8875_DCR, RA8875_DCR_LINESQUTRI_STATUS);
void Adafruit_RA8875::drawFastVLine(int16_t x, int16_t y, int16_t h, uint16_t color)
drawLine(x, y, x, y+h, color);
void Adafruit_RA8875::drawFastHLine(int16_t x, int16_t y, int16_t w, uint16_t color)
drawLine(x, y, x+w, y, color);
Draws a HW accelerated rectangle on the display
@args x[in] The 0-based x location of the top-right corner
@args y[in] The 0-based y location of the top-right corner
@args w[in] The rectangle width
@args h[in] The rectangle height
void Adafruit_RA8875::drawRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
rectHelper(x, y, x+w, y+h, color, false);
Draws a HW accelerated filled rectangle on the display
void Adafruit_RA8875::fillRect(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color)
rectHelper(x, y, x+w, y+h, color, true);
Fills the screen with the spefied RGB565 color
void Adafruit_RA8875::fillScreen(uint16_t color)
rectHelper(0, 0, _width-1, _height-1, color, true);
Draws a HW accelerated circle on the display
@args x[in] The 0-based x location of the center of the circle
@args y[in] The 0-based y location of the center of the circle
@args w[in] The circle's radius
void Adafruit_RA8875::drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
circleHelper(x0, y0, r, color, false);
Draws a HW accelerated filled circle on the display
void Adafruit_RA8875::fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color)
circleHelper(x0, y0, r, color, true);
Draws a HW accelerated triangle on the display
@args x0[in] The 0-based x location of point 0 on the triangle
@args y0[in] The 0-based y location of point 0 on the triangle
@args x1[in] The 0-based x location of point 1 on the triangle
@args y1[in] The 0-based y location of point 1 on the triangle
@args x2[in] The 0-based x location of point 2 on the triangle
@args y2[in] The 0-based y location of point 2 on the triangle
void Adafruit_RA8875::drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
triangleHelper(x0, y0, x1, y1, x2, y2, color, false);
Draws a HW accelerated filled triangle on the display
void Adafruit_RA8875::fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color)
triangleHelper(x0, y0, x1, y1, x2, y2, color, true);
Draws a HW accelerated ellipse on the display
@args xCenter[in] The 0-based x location of the ellipse's center
@args yCenter[in] The 0-based y location of the ellipse's center
@args longAxis[in] The size in pixels of the ellipse's long axis
@args shortAxis[in] The size in pixels of the ellipse's short axis
void Adafruit_RA8875::drawEllipse(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint16_t color)
ellipseHelper(xCenter, yCenter, longAxis, shortAxis, color, false);
Draws a HW accelerated filled ellipse on the display
void Adafruit_RA8875::fillEllipse(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint16_t color)
ellipseHelper(xCenter, yCenter, longAxis, shortAxis, color, true);
Draws a HW accelerated curve on the display
@args curvePart[in] The corner to draw, where in clock-wise motion:
0 = 180-270∞
1 = 270-0∞
2 = 0-90∞
3 = 90-180∞
void Adafruit_RA8875::drawCurve(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint8_t curvePart, uint16_t color)
curveHelper(xCenter, yCenter, longAxis, shortAxis, curvePart, color, false);
Draws a HW accelerated filled curve on the display
0 = 180-270∞
1 = 270-0∞
2 = 0-90∞
3 = 90-180∞
void Adafruit_RA8875::fillCurve(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint8_t curvePart, uint16_t color)
curveHelper(xCenter, yCenter, longAxis, shortAxis, curvePart, color, true);
Helper function for higher level circle drawing code
void Adafruit_RA8875::circleHelper(int16_t x0, int16_t y0, int16_t r, uint16_t color, bool filled)
/* Set X */
writeCommand(0x99);
writeData(x0);
writeCommand(0x9a);
writeData(x0 >> 8);
/* Set Y */
writeCommand(0x9b);
writeData(y0);
writeCommand(0x9c);
writeData(y0 >> 8);
/* Set Radius */
writeCommand(0x9d);
writeData(r);
/* Set Color */
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Draw! */
if (filled)
writeData(RA8875_DCR_CIRCLE_START | RA8875_DCR_FILL);
else
writeData(RA8875_DCR_CIRCLE_START | RA8875_DCR_NOFILL);
waitPoll(RA8875_DCR, RA8875_DCR_CIRCLE_STATUS);
Helper function for higher level rectangle drawing code
void Adafruit_RA8875::rectHelper(int16_t x, int16_t y, int16_t w, int16_t h, uint16_t color, bool filled)
/* Set X */
writeCommand(0x91);
writeData(x);
writeCommand(0x92);
writeData(x >> 8);
/* Set Y */
writeCommand(0x93);
writeData(y);
writeCommand(0x94);
writeData(y >> 8);
/* Set X1 */
writeCommand(0x95);
writeData(w);
writeCommand(0x96);
writeData((w) >> 8);
/* Set Y1 */
writeCommand(0x97);
writeData(h);
writeCommand(0x98);
writeData((h) >> 8);
/* Set Color */
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Draw! */
if (filled)
writeData(0xB0);
else
writeData(0x90);
Helper function for higher level triangle drawing code
void Adafruit_RA8875::triangleHelper(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color, bool filled)
/* Set Point 0 */
writeCommand(0x91);
writeData(x0);
writeCommand(0x92);
writeData(x0 >> 8);
writeCommand(0x93);
writeData(y0);
writeCommand(0x94);
writeData(y0 >> 8);
/* Set Point 1 */
writeCommand(0x95);
writeData(x1);
writeCommand(0x96);
writeData(x1 >> 8);
writeCommand(0x97);
writeData(y1);
writeCommand(0x98);
writeData(y1 >> 8);
/* Set Point 2 */
writeCommand(0xA9);
writeData(x2);
writeCommand(0xAA);
writeData(x2 >> 8);
writeCommand(0xAB);
writeData(y2);
writeCommand(0xAC);
writeData(y2 >> 8);
/* Set Color */
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Draw! */
if (filled)
writeData(0xA1);
else
writeData(0x81);
Helper function for higher level ellipse drawing code
void Adafruit_RA8875::ellipseHelper(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint16_t color, bool filled)
/* Set Center Point */
writeCommand(0xA5);
writeData(xCenter);
writeCommand(0xA6);
writeData(xCenter >> 8);
writeCommand(0xA7);
writeData(yCenter);
writeCommand(0xA8);
writeData(yCenter >> 8);
/* Set Long and Short Axis */
writeCommand(0xA1);
writeData(longAxis);
writeCommand(0xA2);
writeData(longAxis >> 8);
writeCommand(0xA3);
writeData(shortAxis);
writeCommand(0xA4);
writeData(shortAxis >> 8);
/* Set Color */
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Draw! */
writeCommand(0xA0);
if (filled)
writeData(0xC0);
else
writeData(0x80);
waitPoll(RA8875_ELLIPSE, RA8875_ELLIPSE_STATUS);
Helper function for higher level curve drawing code
void Adafruit_RA8875::curveHelper(int16_t xCenter, int16_t yCenter, int16_t longAxis, int16_t shortAxis, uint8_t curvePart, uint16_t color, bool filled)
writeCommand(0xA5);
writeData(xCenter);
writeCommand(0xA6);
writeCommand(0xA7);
writeData(yCenter);
writeCommand(0xA8);
writeCommand(0xA1);
writeCommand(0xA2);
writeCommand(0xA3);
writeCommand(0xA4);
/* Set Color */
writeCommand(0x63);
writeCommand(0x64);
writeCommand(0x65);
/* Draw! */
writeCommand(0xA0);
if (filled)
writeData(0xD0 | (curvePart & 0x03));
else
writeData(0x90 | (curvePart & 0x03));
/************************* Mid Level ***********************************/
void Adafruit_RA8875::GPIOX(boolean on) {
if (on)
writeReg(RA8875_GPIOX, 1);
else
writeReg(RA8875_GPIOX, 0);
void Adafruit_RA8875::PWM1out(uint8_t p) {
writeReg(RA8875_P1DCR, p);
void Adafruit_RA8875::PWM2out(uint8_t p) {
writeReg(RA8875_P2DCR, p);
void Adafruit_RA8875::PWM1config(boolean on, uint8_t clock) {
if (on) {
writeReg(RA8875_P1CR, RA8875_P1CR_ENABLE | (clock & 0xF));
} else {
writeReg(RA8875_P1CR, RA8875_P1CR_DISABLE | (clock & 0xF));
void Adafruit_RA8875::PWM2config(boolean on, uint8_t clock) {
if (on) {
writeReg(RA8875_P2CR, RA8875_P2CR_ENABLE | (clock & 0xF));
} else {
writeReg(RA8875_P2CR, RA8875_P2CR_DISABLE | (clock & 0xF));
Enables or disables the on-chip touch screen controller
void Adafruit_RA8875::touchEnable(boolean on)
if (on)
/* Enable Touch Panel (Reg 0x70) */
writeReg(RA8875_TPCR0, RA8875_TPCR0_ENABLE |
RA8875_TPCR0_WAIT_4096CLK |
RA8875_TPCR0_WAKEDISABLE |
RA8875_TPCR0_ADCCLK_DIV4); // 10mhz max!
/* Set Auto Mode (Reg 0x71) */
writeReg(RA8875_TPCR1, RA8875_TPCR1_AUTO |
// RA8875_TPCR1_VREFEXT |
RA8875_TPCR1_DEBOUNCE);
/* Enable TP INT */
writeReg(RA8875_INTC1, readReg(RA8875_INTC1) | RA8875_INTC1_TP);
else
/* Disable TP INT */
writeReg(RA8875_INTC1, readReg(RA8875_INTC1) & ~RA8875_INTC1_TP);
/* Disable Touch Panel (Reg 0x70) */
writeReg(RA8875_TPCR0, RA8875_TPCR0_DISABLE);
Checks if a touch event has occured
@returns True is a touch event has occured (reading it via
touchRead() will clear the interrupt in memory)
boolean Adafruit_RA8875::touched(void)
if (readReg(RA8875_INTC2) & RA8875_INTC2_TP) return true;
return false;
Reads the last touch event
@args x[out] Pointer to the uint16_t field to assign the raw X value
@args y[out] Pointer to the uint16_t field to assign the raw Y value
@note Calling this function will clear the touch panel interrupt on
the RA8875, resetting the flag used by the 'touched' function
boolean Adafruit_RA8875::touchRead(uint16_t *x, uint16_t *y)
uint16_t tx, ty;
uint8_t temp;
tx = readReg(RA8875_TPXH);
ty = readReg(RA8875_TPYH);
temp = readReg(RA8875_TPXYL);
tx <<= 2;
ty <<= 2;
tx |= temp & 0x03; // get the bottom x bits
ty |= (temp >> 2) & 0x03; // get the bottom y bits
*x = tx;
*y = ty;
/* Clear TP INT Status */
writeReg(RA8875_INTC2, RA8875_INTC2_TP);
return true;
Turns the display on or off
void Adafruit_RA8875::displayOn(boolean on)
if (on)
writeReg(RA8875_PWRR, RA8875_PWRR_NORMAL | RA8875_PWRR_DISPON);
else
writeReg(RA8875_PWRR, RA8875_PWRR_NORMAL | RA8875_PWRR_DISPOFF);
Puts the display in sleep mode, or disables sleep mode if enabled
void Adafruit_RA8875::sleep(boolean sleep)
if (sleep)
writeReg(RA8875_PWRR, RA8875_PWRR_DISPOFF | RA8875_PWRR_SLEEP);
else
writeReg(RA8875_PWRR, RA8875_PWRR_DISPOFF);
/************************* Low Level ***********************************/
void Adafruit_RA8875::writeReg(uint8_t reg, uint8_t val)
writeCommand(reg);
writeData(val);
uint8_t Adafruit_RA8875::readReg(uint8_t reg)
writeCommand(reg);
return readData();
void Adafruit_RA8875::writeData(uint8_t d)
mySPI.transfer(d);
uint8_t Adafruit_RA8875::readData(void)
mySPI.transfer(RA8875_DATAREAD);
uint8_t x = mySPI.transfer(0x0);
return x;
void Adafruit_RA8875::writeCommand(uint8_t d)
mySPI.transfer(RA8875_CMDWRITE);
mySPI.transfer(d);
uint8_t Adafruit_RA8875::readStatus(void)
mySPI.transfer(RA8875_CMDREAD);
return x;
