I can't get any of the Adafruit ILI9341 Example sketches to compile. I keep getting "fatal error: avr/pgmspace.h: No such file or directory"
I have the latest versions of the libraries for Adafruit_GFX.h and Adafruit_ILI9341.h and SPI.h and SD.h and Adafruit_STMPE610.h and Wire.h installed. I'm using the Arduino IDE v. 1.8.3 and have the "Adafruit HUZZAH ESP8266" board selected from the
"Tools>-Boards" dropdown.
My intent is to run these sketches with my "Feather Huzzah with ESP8266" (part# 2821) and my "2.4 TFT FeatherWing" (part #3315).
Can anyone please suggest what I'm doing wrong? I've read and reread the .pdf tutorials for the HUZZAH and for the TFT FeatherWing a bazillion times and I'm following the instructions but I can't get any of the ILI9341 examples to compile. Thanks.
Jim
Can't Get ILI9341 Example Sketches to Compile
- elcantinero
- Franklin97355
Re: Can't Get ILI9341 Example Sketches to Compile
If you set the compile option to verbose in the IDE preferences can you post the error log here using the code button above the reply window to wrap your log in code tags?I can't get any of the Adafruit ILI9341 Example sketches to compile.
- elcantinero
BELOW IS THE ERROR MESSAGE I GET:
Arduino: 1.8.3 (Windows 7), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_98304 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_130823 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_98304 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_130823 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino
Using board 'huzzah' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_98304/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "C:\Users\User\AppData\Local\Temp\arduino_build_98304\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_98304/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "C:\Users\User\AppData\Local\Temp\arduino_build_98304\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_98304/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "C:\Users\User\AppData\Local\Temp\arduino_build_98304\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_98304/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SPI" "C:\Users\User\AppData\Local\Temp\arduino_build_98304\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_98304/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SPI" "C:\Users\User\AppData\Local\Temp\arduino_build_98304\sketch\spitftbitmap.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino_build_98304\preproc\ctags_target_for_gcc_minus_e.cpp"
In file included from C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341/Adafruit_ILI9341.h:25:0,
from C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino:18:
C:\Users\User\Documents\Arduino\libraries\SPI/SPI.h:16:26: fatal error: avr/pgmspace.h: No such file or directory
#include <avr/pgmspace.h>
compilation terminated.
Multiple libraries were found for "Adafruit_GFX.h"
Used: C:\Users\User\Documents\Arduino\libraries\Adafruit_GFX
Not used: C:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library-master
Multiple libraries were found for "SPI.h"
Used: C:\Users\User\Documents\Arduino\libraries\SPI
Not used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Using library Adafruit_GFX in folder: C:\Users\User\Documents\Arduino\libraries\Adafruit_GFX (legacy)
Using library Adafruit_ILI9341 at version 1.0.10 in folder: C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341
Using library SPI at version 1.0 in folder: C:\Users\User\Documents\Arduino\libraries\SPI
exit status 1
Error compiling for board Adafruit HUZZAH ESP8266.
Reason: Please use code tags when posting code or logs to the forums. It preserves formatting and makes it easier for everyone to read the code. Click the code button above the reply box and past your code between the tags created.
- Franklin97355
The spi.h file is for avr chips and you are using an ESP8266. I'll see if there is an update.
- adafruit2
why do you have a 'user' version of the SPI library in
???? did you install it? it should not be there! :/
- elcantinero
I'm not sure how the 'user' version of the SPI library got there. Obviously, I must have put it there for some reason. I have reinstalled the Arduino IDE so now the SPI library should be the proper one that comes with the IDE.
- elcantinero
After reinstalling the Arduino IDE, I again tried to compile the Adafruit ILI9341 spitfibit sketch but got the same error. The error message is shown below. I hope I loaded it correctly.
C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\tools-builder -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_508950 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_504368 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino
C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\arduino-builder -compile -logger=machine -hardware C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\tools-builder -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_508950 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_504368 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\Adafruit_GFX\Adafruit_GFX.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\Adafruit_GFX\glcdfont.c" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\Adafruit_ILI9341.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI\SPI.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\SD\src\File.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\SD\src\SD.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\SD\src\utility\Sd2Card.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\SD\src\utility\SdFile.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\Documents\Arduino\libraries\SD\src\utility\SdVolume.cpp" -o "nul"
Generating function prototypes...
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino_build_508950\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\User\AppData\Local\Temp\arduino_build_508950\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_508950/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_GFX" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp" -o "C:\Users\User\AppData\Local\Temp\arduino_build_508950\sketch\spitftbitmap.ino.cpp.o"
In file included from C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\spitftbitmap\spitftbitmap.ino:18:0:
C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341/Adafruit_ILI9341.h:162:33: error: no members matching 'Adafruit_GFX::drawRGBBitmap' in 'class Adafruit_GFX'
using Adafruit_GFX::drawRGBBitmap; // Check base class first
Used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Not used: C:\Users\User\Documents\Arduino\libraries\SPI
Multiple libraries were found for "SD.h"
Used: C:\Users\User\Documents\Arduino\libraries\SD
Not used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SD
Not used: C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\libraries\SD
Using library SPI at version 1.0 in folder: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
Using library SD at version 1.0.5 in folder: C:\Users\User\Documents\Arduino\libraries\SD
exit status 1
Compiling sketch...
exit status 1
- Franklin97355
Next step is to close the Arduino IDE and delete the C:\Users\User\AppData\Local\Arduino15\ folder then empty trash and restart the IDE. See if that helps.
- adafruit_support_rick
That's a different error. Looks like you have an old version of Adafruit_GFX in your libraries folderelcantinero wrote:C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341/Adafruit_ILI9341.h:162:33: error: no members matching 'Adafruit_GFX::drawRGBBitmap' in 'class Adafruit_GFX'
- elcantinero
You are correct. Thank you very much. I did have an old version of the GFX library loaded. I deleted it and loaded a newer version. Now 4 of the 10 example sketches from Adafruit ILI9341 do compile and only six of the example sketches don't compile. However, one of them that does not compile is the only example I'm really interested in. It is called "fulltest_featherwing" and my error message is attached below. I think the problem may be the Adafruit STMPE610 library but I just loaded this one two days ago and I don't think a newer version exists. If you can help me with this, I'll be satisfied and won't bother you any more. Thanks for all the help you've given me so far.
C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\arduino-builder -dump-prefs -logger=machine -hardware C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\tools-builder -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_701206 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_773049 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\fulltest_featherwing\fulltest_featherwing.ino
C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\arduino-builder -compile -logger=machine -hardware C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware -hardware C:\Users\User\AppData\Local\Arduino15\packages -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\tools-builder -tools C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\hardware\tools\avr -tools C:\Users\User\AppData\Local\Arduino15\packages -built-in-libraries C:\Users\User\Downloads\arduino-1.8.3-windows\arduino-1.8.3\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10803 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_701206 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_773049 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.mkspiffs.path=C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341\examples\fulltest_featherwing\fulltest_featherwing.ino
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610" "C:\Users\User\AppData\Local\Temp\arduino_build_701206\sketch\fulltest_featherwing.ino.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610" "C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI\SPI.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610" "-IC:\Users\User\Documents\Arduino\libraries\Wire\utility" "C:\Users\User\Documents\Arduino\libraries\Wire\Wire.cpp" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610" "-IC:\Users\User\Documents\Arduino\libraries\Wire\utility" "C:\Users\User\Documents\Arduino\libraries\Wire\utility\twi.c" -o "nul"
"C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\User\AppData\Local\Temp\arduino_build_701206/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10803 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\User\Documents\Arduino\libraries\Wire" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_ILI9341" "-IC:\Users\User\Documents\Arduino\libraries\SD\src" "-IC:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610" "-IC:\Users\User\Documents\Arduino\libraries\Wire\utility" "C:\Users\User\Documents\Arduino\libraries\Wire\utility\twi.c" -o "C:\Users\User\AppData\Local\Temp\arduino_build_701206\preproc\ctags_target_for_gcc_minus_e.cpp"
C:\Users\User\Documents\Arduino\libraries\Wire\utility\twi.c:25:20: fatal error: avr/io.h: No such file or directory
#include <avr/io.h>
Multiple libraries were found for "Wire.h"
Used: C:\Users\User\Documents\Arduino\libraries\Wire
Not used: C:\Users\User\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire
Using library Wire at version 1.0 in folder: C:\Users\User\Documents\Arduino\libraries\Wire
Using library Adafruit-GFX-Library at version 1.2.2 in folder: C:\Users\User\Documents\Arduino\libraries\Adafruit-GFX-Library
Using library Adafruit_STMPE610 at version 1.0.1 in folder: C:\Users\User\Documents\Arduino\libraries\Adafruit_STMPE610
exit status 1
You appear to have a version of the wire library in your user libraries folder. It's using that instead of the ESP8266 library.
I suggest you clean out your user libraries folder. You seem to have a lot of junk in it.
- elcantinero
Thank you VERY MUCH. I removed the Wire library and that solved the problem.
Jim
Jim
