M0 Feather reset when running DC motor with Motor FeatherWin
Re: M0 Feather reset when running DC motor with Motor Feathe
by adafruit_support_bill on Sat Aug 03, 2019 11:46 am
The first thing to do is suppress as much of the noise as you can at the source. 3 capacitors soldered to the motor leads as shown here is a good way to do that: https://learn.adafruit.com/adafruit-mot ... aq-2861890
If that does not solve it, you can use the circuit posted above - except connect the resistor to GND instead of 3.3v.
by IoTAll on Mon Aug 19, 2019 1:50 pm
I couldn't add capacitors on the DC motor itself as I cannot access to it (fully enclosed in plastic) so I connecte the GPIO pin which was causing issue to Ground with both a resistor and a capacitor.
It works great now!!
Thanks a lot for the help!
IoTAll
by adafruit_support_bill on Mon Aug 19, 2019 2:08 pm
Good to hear that worked. Thanks for the update.
