I believe I have a defective Adafruit feather. Whenever I try to push code from Arduino’s IDE I end up getting a verification error. I’ve attached the error code below
The reset button will let the code get pushed, but ultimately the code seems to fail to write onto the board. I’ve tried different code examples, each one behaves in a similar fashion but each program seems to fail at a different byte (my code fails at 0x0002 the example blink fails at 0x0008) I have another feather that works just fine on the same PC, and I get the some errors on three different machines.
Archiving built core (caching) in: C:\Users\CODYSA~1\AppData\Local\Temp\arduino_cache_322172\core\core_adafruit_avr_feather32u4_a94ab6aaf61dfb93b4a8079c694a14c2.a
Sketch uses 23686 bytes (82%) of program storage space. Maximum is 28672 bytes.
Global variables use 373 bytes of dynamic memory.
PORTS {COM3, } / {COM3, } => {}
PORTS {COM3, } / {} => {}
PORTS {} / {} => {}
PORTS {} / {COM5, } => {COM5, }
Found upload port: COM5
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr/bin/avrdude -CC:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf -v -patmega32u4 -cavr109 -PCOM5 -b57600 -D -Uflash:w:C:\Users\CODYSA~1\AppData\Local\Temp\arduino_build_594406/Post_Daisho_Eyes.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.10.0_x86__mdqgnx93n4wtt\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size#Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .
Found programmer: Id = "CATERIN"; type = S
Software Version = 1.0; No Hardware Version given.
Programmer supports auto addr increment.
Programmer supports buffered memory access with buffersize=128 bytes.
Programmer supports the following devices:
Device code: 0x44
avrdude: devcode selected: 0x44
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9587 (probably m32u4)
avrdude: reading input file "C:\Users\CODYSA~1\AppData\Local\Temp\arduino_build_594406/Post_Daisho_Eyes.ino.hex"
avrdude: writing flash (23686 bytes):
Writing | ################################################## | 100% 2.02s
avrdude: 23686 bytes of flash written
avrdude: verifying flash memory against C:\Users\CODYSA~1\AppData\Local\Temp\arduino_build_594406/Post_Daisho_Eyes.ino.hex:
avrdude: load data flash data from input file C:\Users\CODYSA~1\AppData\Local\Temp\arduino_build_594406/Post_Daisho_Eyes.ino.hex:
avrdude: input file C:\Users\CODYSA~1\AppData\Local\Temp\arduino_build_594406/Post_Daisho_Eyes.ino.hex contains 23686 bytes
avrdude: reading on-chip flash data:
Reading | #########################################An error occurred while uploading the sketch
######### | 100% 0.33s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0002
0xda != 0xe8
avrdude: verification error; content mismatch
avrdude done.
Vincent
Adafruit Feather 32u4 Basic Proto
- vinjrom
- Back.jpg (339.03 KiB) Viewed 160 times
- Front.jpg (326.36 KiB) Viewed 160 times
