SPIflash on feather MO express
BernaFiesta
Post by BernaFiesta »
Hello!
I'm stuck in a temperature/humidity/pressure experiment, because I can't format the SPIflash (I'd like to code with arduino ide)
The fafts_format doesn't work.. Maybe should I change something in the code? (I'm a beginner on electronic, so... I'm a bit lost)
Here is the code (and lower the answer, with error message):
// Adafruit SPI Flash FatFs Format Example
// Author: Tony DiCola
// This will partition and format the SPI flash to have a new
// blank FAT filesystem.  This is useful for resetting the flash
// filesystem and erasing all the old data.  This is also a good
// example of using the low-level FatFs library functions directly
// instead of wrappers from this library.  See documentation on
// FatFs functions here:
//   http://elm-chan.org/fsw/ff/00index_e.html
// !!  NOTE: YOU WILL ERASE ALL DATA BY RUNNING THIS SKETCH!  !!
// Usage:
// - Modify the pins and type of fatfs object in the config
//   section below if necessary (usually not necessary).
// - Upload this sketch to your M0 express board.
// - Open the serial monitor at 115200 baud.  You should see a
//   prompt to confirm formatting.  If you don't see the prompt
//   close the serial monitor, press the board reset buttton,
//   wait a few seconds, then open the serial monitor again.
// - Type OK and enter to confirm the format when prompted.
// - Partitioning and formatting will take about 30-60 seconds.
//   Once formatted a message will be printed to notify you that
//   it is finished.
#include <SPI.h>
#include <Adafruit_SPIFlash.h>
#include <Adafruit_SPIFlash_FatFs.h>
// Include the FatFs library header to use its low level functions
// directly.  Specifically the f_fdisk and f_mkfs functions are used
// to partition and create the filesystem.
#include "utility/ff.h"
// Configuration of the flash chip pins and flash fatfs object.
// You don't normally need to change these if using a Feather/Metro
// M0 express board.
#define FLASH_TYPE     SPIFLASHTYPE_W25Q16BV  // Flash chip type.
                                              // If you change this be
                                              // sure to change the fatfs
                                              // object type below to match.
#define FLASH_SS       SS1                    // Flash chip SS pin.
#define FLASH_SPI_PORT SPI1                   // What SPI port is Flash on?
Adafruit_SPIFlash flash(FLASH_SS, &FLASH_SPI_PORT);     // Use hardware SPI
// Alternatively you can define and use non-SPI pins!
// Adafruit_SPIFlash flash(FLASH_SCK, FLASH_MISO, FLASH_MOSI, FLASH_SS);
Adafruit_W25Q16BV_FatFs fatfs(flash);
  // Initialize serial port and wait for it to open before continuing.
  Serial.begin(115200);
  while (!Serial) {
    delay(100);
  Serial.println("Adafruit SPI Flash FatFs Format Example");
  // Initialize flash library and check its chip ID.
  if (!flash.begin(FLASH_TYPE)) {
    Serial.println("Error, failed to initialize flash chip!");
    while(1);
  Serial.print("Flash chip JEDEC ID: 0x"); Serial.println(flash.GetJEDECID(), HEX);
  // Wait for user to send OK to continue.
  Serial.setTimeout(30000);  // Increase timeout to print message less frequently.
  do {
    Serial.println("!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!");
    Serial.println("This sketch will ERASE ALL DATA on the flash chip and format it with a new filesystem!");
    Serial.println("Type OK (all caps) and press enter to continue.");
  while (!Serial.find("OK"));
  // Call fatfs activate to make it the active chip that receives low level fatfs
  // callbacks.  This is necessary before making any manual fatfs function calls
  // (like the f_fdisk and f_mkfs functions further below).  Be sure to call
  // activate before you call any fatfs functions yourself!
  fatfs.activate();
  // Partition the flash with 1 partition that takes the entire space.
  Serial.println("Partitioning flash with 1 primary partition...");
  DWORD plist[] = {100, 0, 0, 0};  // 1 primary partition with 100% of space.
  uint8_t buf[512] = {0};          // Working buffer for f_fdisk function.
  FRESULT r = f_fdisk(0, plist, buf);
  if (r != FR_OK) {
    Serial.print("Error, f_fdisk failed with error code: "); Serial.println(r, DEC);
    while(1);
  Serial.println("Partitioned flash!");
  // Make filesystem.
  Serial.println("Creating and formatting FAT filesystem (this takes ~60 seconds)...");
  r = f_mkfs("", FM_ANY, 0, buf, sizeof(buf));
  if (r != FR_OK) {
    Serial.print("Error, f_mkfs failed with error code: "); Serial.println(r, DEC);
    while(1);
  Serial.println("Formatted flash!");
  // Finally test that the filesystem can be mounted.
  if (!fatfs.begin()) {
    Serial.println("Error, failed to mount newly formatted filesystem!");
    while(1);
  // Done!
  Serial.println("Flash chip successfully formatted with new empty filesystem!");
  // Nothing to be done in the main loop.
  delay(100);
And here is the answer:
Flash chip JEDEC ID: 0x1401501
Couldn't read sector before performing write!
Error, f_fdisk failed with error code: 1
If someone could help, it would be great, thank you!
Reason: added [CODE] tags
danhalbert
Re: SPIflash on feather MO express
Post by danhalbert »
A recent code change broke this. We're working on a fix, but in the meantime, you can follow the instructions here to retrieve an older version of the formatting program: viewtopic.php?f=57&t=127244#p634694
BernaFiesta
NICE! Thank you very much!!!
rogerthat
Post by rogerthat »
I have exactly the same problem with Feather M0-ATSAMD21+ATWINC1. I get the message:
Flash chip JEDEC ID: 0x0
Couldn't erase sector before performing write!
I loaded the old 1.0.0 library as suggested in this post but no luck. Obviously erase also fails.
Need this fixed since we are porting from a teensy with EEPROM and we need some NVM variable storage. Thanks.
danhalbert
The Feather M0 WiFi - ATSAMD21 + ATWINC1500 does not have an external SPI flash chip, which is what that program is looking for. I'm not sure: are you trying to erase the internal flash on the SAMD21? Loading any Arduino program will do that as a side-effect.
rogerthat
Post by rogerthat »
OK. That explains that. Thanks for the quick reply. How do I read and write data to the SAMD21 ? I just need to save some configuration data between power up.
danhalbert
Are you using Arduino or CircuitPython?
rogerthat
Post by rogerthat »
Arduino
danhalbert
Check out this library, which will allow you use a section of flash as simulated EEPROM: https://github.com/cmaglie/FlashStorage. Study the README warnings about not wearing out the flash. This library is available in the Library Manager as "FlashStorage by Various".
