Feather M0 Bluefruit LE not working
by tweghorst on Tue Jan 16, 2018 1:30 pm
I bought three Feather M0 Bluefruit LE and one of them (using the exact same sketch) will not enable the bluetooth.
When Requesting Bluefruit M0 info using "ble.info();" all i get from the serial monitor is...
Requesting Bluefruit M0 info:
tweghorst
Re: Feather M0 Bluefruit LE not working
by adafruit_support_mike on Fri Jan 19, 2018 2:03 am
To make sure I understand, you have two other boards that give the expected response when running the same code. Is that correct?
by tweghorst on Fri Jan 19, 2018 9:02 am
That is correct, the other two boards are fine with the same code on them.
tweghorst
by adafruit_support_mike on Sun Jan 21, 2018 3:19 am
Thank you. That means the one that isn't working has some kind of hardware problem.
Send a note containing a link to this thread and your order number to support@adafruit.com. The folks there will get you a replacement.
(#2995)
by tweghorst on Mon Jan 22, 2018 9:23 am
Thank you.
tweghorst
