Hoping someone can help me with this. Im trying to get a normal 2x16 I2C LCD working with my feather Huzzah esp8266. Im a fairly frequent Arduino user and im using the same libraires that i use with success with Uno's and Nanos for various projects.
I have managed to use my Huzzah on other projects including connecting to Adafruit IO, so I "think" I have installed what I need into the Arduino IDE.
My problem is errors when compiling the below simple sketch:
#include <Wire.h>
#include <LiquidCrystal_I2C.h>
LiquidCrystal_I2C lcd(0x3F);
//LiquidCrystal_I2C lcd(0x3F, 2, 1, 0, 4, 5, 6, 7, 3, POSITIVE); // Set the LCD I2C address
Wire.begin(4,5);
lcd.begin(16,2);
lcd.clear();
lcd.setCursor(0,1);
lcd.print("hello world");
// put your main code here, to run repeatedly:
The errors I get are:
Arduino: 1.6.8 (Windows 10), Board: "Adafruit HUZZAH ESP8266, 80 MHz, 256000, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Jim\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Jim\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Jim\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=256000,FlashSize=4M3M -ide-version=10608 -build-path "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Jim\Documents\Arduino\sketch_jan20a\sketch_jan20a.ino"
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\Jim\AppData\Local\Arduino15\packages" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\Jim\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "C:\Users\Jim\Documents\Arduino\libraries" -fqbn=esp8266:esp8266:huzzah:CpuFrequency=80,UploadSpeed=256000,FlashSize=4M3M -ide-version=10608 -build-path "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\Jim\Documents\Arduino\sketch_jan20a\sketch_jan20a.ino"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire\Wire.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\FastIO.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\I2CIO.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LCD.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_I2C.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_I2C_ByVac.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SI2C.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR2W.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR3W.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\SI2CIO.cpp" -o "nul"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp" -o "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp" -o "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\sketch\sketch_jan20a.ino.cpp.o"
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\Wire\Wire.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\FastIO.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\I2CIO.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LCD.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal_I2C.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal_I2C_ByVac.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal_SI2C.cpp.o
Using previously compiled file: C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal_SR.cpp.o
"C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10608 -DARDUINO_ESP8266_ESP12 -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_ESP12" -DESP8266 "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\adafruit" "-IC:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal" "-IC:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\utility" "C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp" -o "C:\Users\Jim\AppData\Local\Temp\buildd45c876e61838ef4600dd257ec127457.tmp\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp.o"
In file included from C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:35:0:
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp: In member function 'uint8_t LiquidCrystal_SR1W::clearSR()':
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:77:24: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
SR1W_ATOMIC_WRITE_LOW(srRegister, srMask);
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.h:293:79: note: in definition of macro 'SR1W_ATOMIC_WRITE_LOW'
#define SR1W_ATOMIC_WRITE_LOW(reg, mask) ATOMIC_BLOCK(ATOMIC_RESTORESTATE) { *reg &= ~mask; }
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:86:22: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
fio_bit reg_val = *srRegister;
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:95:5: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
*srRegister = bit_high;
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:96:5: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
*srRegister = bit_low;
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:101:4: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp: In member function 'uint8_t LiquidCrystal_SR1W::loadSR(uint8_t)':
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:139:24: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:144:6: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:145:6: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:151:26: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.cpp:158:27: error: invalid type argument of unary '*' (have 'fio_register {aka unsigned char}')
SR1W_ATOMIC_WRITE_HIGH(srRegister, srMask);
C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal\LiquidCrystal_SR1W.h:294:80: note: in definition of macro 'SR1W_ATOMIC_WRITE_HIGH'
#define SR1W_ATOMIC_WRITE_HIGH(reg, mask) ATOMIC_BLOCK(ATOMIC_RESTORESTATE) { *reg |= mask; }
Using library Wire at version 1.0 in folder: C:\Users\Jim\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\Wire
Using library NewliquidCrystal in folder: C:\Users\Jim\Documents\Arduino\libraries\NewliquidCrystal (legacy)
exit status 1
Error compiling for board Adafruit HUZZAH ESP8266.
many thanks in advance
