MO Datalogger serial issue
MikeSBlankenship
Post by MikeSBlankenship »
I am having an issue with a SAMD21 module from Adafruit with the serial port(M0 Datalogger). I am using the built in TX/RX hardware port and I can see all my data in the serial monitor. However I have the TX/RX pins connected to a MAX3232 driver IC. I am not able to see ANY data on the physical TX pin.
I then tried another Module with no MAX3232 chip and I still cannot see any data
Below is the sample I am using. I even tried to use Serial.Write, and like before it shows up in the serial monitor but there is no data on the actual TX pin. I am using 9600 baud, and I have set the scope to 100uS sweep time. Im thinking it uses the USB UART, but how do I set this to transmit directly out of the Physical TX pin?
void setup(){
void loop(){
  Serial.write(45); // send a byte with the value 45
   int bytesSent = Serial.write("hello"); //send the string "hello" and return the length of the string.
Attached is my setup, any help is appreciated.
mike
Franklin97355
Re: MO Datalogger serial issue
Post by Franklin97355 »
The hardware serial pins are Serial1.
MikeSBlankenship
Thanks Franklin that fixed it!
