I built a custom pageturn pedal with a Feather 32u4 ble. It has two operation modes: First is acting as ble HID device and sending keypresses. Second is acting as MIDI USB device sending MIDI commands (currently NoteOn and NoteOff only).
Now I got a new tablet as scorereader that supports MIDI over ble, which allows me to use all buttons, instead of being limited to 6 "pedals". (ScoreReader is the excellent MobileSheets Pro that supports both pedal and MIDI external controls).
So, my question is, is it possible to set up the Feather for BLE HID and MIDI at the same time and switch operation mode on the fly? I did a quick test by implementing the MIDI example code into my working sketch, but this didn't go well.
Further, in MIDI mode, is it possible to have BLE and USB MIDI active at the same time, e.g. when pressing a button, send NoteOn 60 to a device that is attached by either BLE (tablet) or USB (PC)?
If you need my code, feel free to ask.
Kind regards!
Ble HID and MIDI + USB midi in one sketch
- TheNothingMan
Re: Ble HID and MIDI + USB midi in one sketch
You should be able to swap back and forth between the two modes by calling AT+BLEKEYBOARDEN and AT+BLEMIDIEN when you want to emit one kind of packet or the other.
We haven't tested that though, so you'll have to see how it works in practice. You may end up needing to re-pair the device every time you change modes.
- TheNothingMan
Thanks, I will see what I can do and report if I get it done or have other problems.
- TheNothingMan
It worked as suggested. Thanks!
