So far, I can only connect to one at a time, and can connect to one or the other at will by resetting the currently connected feather, causing the central to connect to the other feather.
I've tried looking at the central_bleuart_multi example without any good clues, since the code is quite different when using bleuart.
I feel like I'm missing something simple. My code for the central feather is attached, please give it a glance over and see if there are any glaring errors.
#include <bluefruit.h>
bool signalPrinted = false;
uint8_t ecgSignal1[20];
uint8_t ecgSignal2[20];
bool ecgSignal1Received = false;
bool ecgSignal2Received = false;
BLEClientService siggens(0x0dd756a1fdd844c082bff7517ae37455); //IRONMAN
BLEClientCharacteristic sigc(0xdce59ddcb38f49af83b098feb8a3c592);
BLEClientService siggens2(0x0dd756a1fdd844c082bff7517ae37454);
BLEClientCharacteristic sigc2(0xdce59ddcb38f49af83b098feb8a3c591);
void setup()
Serial.begin(9600);
Serial.println("BLE ECG Central");
Serial.println("------------------\n");
Bluefruit.begin(0, 2);
Bluefruit.setName("BLE ECG Central");
siggens.begin();
sigc.setNotifyCallback(hrm_notify_callback);
sigc.begin();
siggens2.begin();
sigc2.setNotifyCallback(hrm_notify_callback2);
sigc2.begin();
Serial.println("Notify Callback Set");
Serial.println("Characteristic begin'd");
// Callbacks for Central
Bluefruit.Central.setDisconnectCallback(disconnect_callback);
Bluefruit.Central.setConnectCallback(connect_callback);
Bluefruit.Scanner.setRxCallback(scan_callback);
Bluefruit.Scanner.restartOnDisconnect(true);
Bluefruit.Scanner.setInterval(160, 80); // in unit of 0.625 ms
Bluefruit.Scanner.filterUuid(siggens.uuid, siggens2.uuid);
Bluefruit.Scanner.useActiveScan(false);
Bluefruit.Scanner.start(0); // // 0 = Don't stop scanning after n seconds
Serial.println("Settings set. Scanning.");
void loop()
if (ecgSignal1Received && ecgSignal2Received) {
for (int x = 0; x < 20; x++) {
Serial.print(ecgSignal1[x]);
Serial.print(" ");
Serial.print(ecgSignal2[x]);
Serial.print(" ");
Serial.println();
void scan_callback(ble_gap_evt_adv_report_t* report)
Bluefruit.Central.connect(report);
Serial.println("Connected");
void connect_callback(uint16_t conn_handle)
siggens.discover(conn_handle);
Serial.println("Service discovered");
sigc.discover();
Serial.println("Characteristic discovered");
sigc.enableNotify();
Serial.println("Notify enabled");
siggens2.discover(conn_handle);
Serial.println("Service 2 discovered");
sigc2.discover();
Serial.println("Characteristic 2 discovered");
sigc2.enableNotify();
Serial.println("Notify 2 enabled");
void disconnect_callback(uint16_t conn_handle, uint8_t reason)
(void) conn_handle;
(void) reason;
Serial.println("disconnected");
void hrm_notify_callback(BLEClientCharacteristic* chr, uint8_t* data, uint16_t len)
for (int i = 0; i < len; i++) {
ecgSignal1[i] = data[i];
// Serial.println(data[i]);
ecgSignal1Received = true;
void hrm_notify_callback2(BLEClientCharacteristic* chr, uint8_t* data2, uint16_t len)
ecgSignal2[i] = data2[i];
// Serial.print(" ");
// Serial.println(data2[i]);
ecgSignal2Received = true;
