Hi there,
I am trying to use a 3x AAA battery holder (https://www.exp-tech.de/zubehoer/batter ... -2-pin-jst) to power my feather. Unfortunately it is not working as expected.
When turning on the power only id #13 is blinking for a moment, then nothing happens.
Intersting: when first connecting the Feather via USB to my notebook and then turning on the supply by the battery holder, it does work.
Anyone an idea how to get the Feather running without first connect it via USB?
Thanks in advance!
Feather M0 with Wifi
- Franklin97355
Re: Feather M0 with Wifi
You may be trying to access the serial port in your code and that might stop the program from running. Also, the Feathers have a charging circuit designed for 3.7-volt lipo batteries and your batteries or the Feather may be damaged if you use other types of batteries in the JST connector.
- dabrams
Try connecting to the USB pin. That allows you to power the board from an external 5V supply. The three batteries give 4.3V and should work until they get below the dropout voltage of the SPX3819 (340mV). However, you probably would be better off using 4 AA cells to get 6V so that you get longer life out of the batteries before the regulator cannot supply 3.3V. The voltage regulator can handle up to 16V as long as the power dissipation does not cause it to shut down.
