Hi - I have two questions that would appreciate if someone helps me with:
- What is the implementation of ms2tick you are using in your library (i.e. what is the frequency used for the timer 32.786KHz or 16MHz)?
- For the xTimer you're using as SoftwareTimer, can I create multiple timers with different routines and periods. One of the ISRs is long, so, I need the other timer to interrupt this ISR (i.e. nested interrupts with priorities)?
Mahmoud
xTimer
