Command line for Feather RFM95
mike_adafruit
Post by mike_adafruit »
I am trying to upload, using the command line, binary files created in the Arduino IDE (under Fedora Linux) using a command like
/home/mg/.arduino15/packages/arduino/tools/bossac/1.7.0/bossac --port=ttyACM0 -e -w -R dev/Feather/Feather_9X_TX-single/Feather_9X_TX-single.ino.feather_m0.bin
It seems to work OK, however I am forced to put the Feather into programming mode (double tap of the reset button).
Is there anyway to avoid that step? (after all, the IDE does it fine!)
Thanks.
adafruit_support_mike
Re: Command line for Feather RFM95
To auto-reboot the microcontroller and make it launch the bootloader, you have to open a 1200 baud Serial connection and then close it again. That's the secret-knock the Arduino IDE uses with microcontrollers that handle USB internally.
mike_adafruit
Can you suggest an incantation over command line to open and then close that kind of connection?
