Feather ESP32 Port Not Recognized
- jimwims
I received a Feather ESP32 today and am trying to upload Micropython to it from my iMac 10.13.6. I am unable to identify the port to use. Running ls -1 /dev/tty.* shows only the same 2 ports (/dev/tty.Bluetooth-Incoming-Port /dev/tty.Makeblock-ELETSPP) regardless of whether the Feather is connected with the USB cable. I use the same port on the Mac and the same USB cable to connect to an ESP-WROVER-KIT regularly. When it is connected, two additional ports are listed (/dev/tty.usbserial-00001014A /dev/tty.usbserial-00001014B). Can you tell me where I have gone wrong? TIA
- jimwims
Re: Feather ESP32 Port Not Recognized
Problem solved, Tnx
- danhalbert
Thanks for following up!
- Rjp663
Folks,
I'm seeing the same issue. Could you share what the remedy was?
Rick
Rick
- jimwims
I am running Micropython on my ESP32. The below webpage includes a reminder about downloading a SiLabs CP2104 driver if you are using the Arduino IDE. I'm not using that IDE but decided to try downloading the driver anyway. That seems to have solved the problem.
https://learn.adafruit.com/adafruit-huz ... rduino-ide
Hope this solves your problem.
- Rjp663
All,
Interesting problem, see the link below on how to solve this issue.
viewtopic.php?f=57&t=139713
Rick
Rick
- laureneckert
Hi, I'm having the same issue but I have Windows 10. These remedies are all for Mac OS... what would be the steps for me to do with my OS to fix this?
