Internal malfunction FeatherWing
powersoft
Post by powersoft »
A good evening,
After I have solved the problem with the pen numbers, the next problem.
When everything is mounted (FeatherESP32 & FeatherWings 3.5"), it sometimes happens that the loaded program starts running.
If I put everything down on my desk (this with minimum vibration) everything disappears and I keep a white screen, and this will even at resetting.
I suspect that a connection within the FeaterWings is not in order.
How do we proceed with this now?
adafruit_support_carter
Re: Internal malfunction FeatherWing
This sounds like a connection issue between the Feather and the Wing. Are you sure the two are solidly connected together?
powersoft
Post by powersoft »
I contacted the seller, ant together we have looked to the problem.
At the end I received a brand new version, and this one is working perfect.
Thank for your effort, and thanks Kiwi-Electronincs in the Netherlands for their great support
