LoRa Disable Enable
Kelmer
LoRa Disable Enable
Post by Kelmer »
My setup consists of a feather MO with a LoRa module that has an Ethernet board stacked on top. The board seems to randomly freeze itself when working so I presumed the issue to be that I am not disabling the radio while the Ethernet board is communicating online. I have attempted to temporarily disable to LoRa module with the recommended pinmode(8, INPUT_PULLUP) but once I do this, I can't get the radio to work again. I have tried setting it to pinmode(8, INPUT), digitalwrite(8, HIGH), digitalwrite(8 LOW), and nothing seems to bring it back online once I have run the pull up code. How do I get this setup to work with the radio module running then stopping for the Ethernet module then resuming afterwards?
Thanks in advance for the help.
