Adafruit Feather M0 Basic Proto wrong boot loader
- patf123
I received 3 Feather M0 Basic Proto boards and they are all programmed with the Circuit Python boot loader. The catalogue clearly states that these are Arduino boot loader boards. I have no way to reprogram the boot loader since it requires a programmer like the Segger J-Link. I'm not sure what to do at this point. I don't think Circuit Python will fit our needs.
- jerryn
Re: Adafruit Feather M0 Basic Proto wrong boot loader
Just to check, By Circuit Python Bootloader, I assume you mean the "UF2" bootloader and you see a USB device named "FEATHERBOOT" when you connect the board.
The "UF2" bootloader works for both Arduino and Circuit Python. You should be able to load Arduino sketches as normal.
Note: I don't represent Adafruit, just trying to help...
- adafruit_support_carter
What @jerryn said is correct. Go ahead and try programming it with Arduino - it should work just fine.
- patf123
Thanks for the info. I'm still having problems though. It does go into UF2 boot but when I try to load an Arduino Sketch it can't find the serial port to connect to. Before trying to upload the sketch the device manager in Windows 7 shows the feather on com21 after the load attempt the device manager updates and shows other devices feather M0 and on a different com port it now shows "AF M0 UF2 Webdummy (0015:04) (COM20). I try loading again but the com port does not show on the port select menu. Also the device manager says that the driver is not loaded even though I installed the drivers. I running this on a windows 7 box.
Windows may be reassigning the COM port after the upload. When you are in bootloader mode, are you seeing the "FEATHERBOOT" folder show up without any issues? Post the full output of the messages that are being printed in the Arduino console when you attempt an upload.
- patf123
Thanks I'll check that but the problem occurs when the IDE tries to upload. In verbose mode I see it trying to locate the serial port, in this case Com21 and then when the board goes into UF2 mode the com port disappears from the verbose output listing and it no longer shows up on the IDE PORT selection list. The port literally re-enumerates to a new port number right after the Feather enters manual upload mode (slow blinking LED). If I put the board into manual upload mode the IDE always loses the port number and never finds it until i reset it to the Circuit Python loader. This is really weird.
- patf123
Here's some screen shots and the listing from the output window on the IDE.
Thank again for your help.
- IDE error output.txt
- Output from the IDE during upload
- (68.59 KiB) Downloaded 8 times
- Initial port configuration in device manager
- Device manager Featehr in intial startup.PNG (59.33 KiB) Viewed 171 times
- port configuration in device manager after resetting to manual boot mode
- Device manager Featehr after double press of reset UF2 mode.PNG (68.73 KiB) Viewed 171 times
Sorry - for some reason didn't notice that you're using the Basic Proto. That one may have come without the UF2 bootloader. You should still be able to program it with Arduino, but you can't double reset and get the FEATHERBOOT folder with that one.
Make sure you've installed the drivers for Win 7:
https://learn.adafruit.com/adafruit-fea ... -only-6-11
And then you should be able to select the board as shown here:
https://learn.adafruit.com/adafruit-fea ... blink-6-21
And if you still have trouble, try this:
https://learn.adafruit.com/adafruit-fea ... help#faq-4
- patf123
Thanks for the help. I've done all that before. It keeps losing the serial port when it tries to upload the sketch. The IDE never identifies the board on the serial port list like the examples and I have the latest drivers. My device manager says there is no driver loaded after I try to upload and it changes the port number and description as per the screen captures. At this point I have no clue as to why this is happening.
Did you recently update the Arduino IDE?
- patf123
Yes I did to 1.8.5.
- patf123
I finally got the featherboot folder after double clicking the reset. Now I just have to figure out how to load Arduino sketches. Is there a tutorial for that?
Thanks again for the help.
Interesting - do you have any idea what changed to make it finally show up?
Here's how to set things up for Arduino. If you run into issues, let us know:
https://learn.adafruit.com/adafruit-fea ... roto/setup
- patf123
I tried deleting the drivers, reloading them and restarting the pc. That seemed to clear up the problem. I should have tried that earlier. Thanks again for all your help. I'm up and running now!
Pat.
Pat.
Glad you got it working. It may have been Arduino that installed drivers that messed things up. We've seen that in some instances:
https://learn.adafruit.com/adafruit-cir ... duino-71-1
