I'm new in the maker/ board community and recently purchased the feather 32u4 with Bluetooth module.
When I try to upload the example sketches to the device, I receive the following error:
Arduino: 1.8.7 (Linux), Board: "Adafruit Feather 32u4"
Sketch uses 4052 bytes (14%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type =
Software Version = .; Hardware Version = x.�
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
I've already double checked the board configuration and COM port, and the IDE recognize them.
Any advice on how to proceed?
Thank you,
feather 32u4 programmer not responding
- adafruit2
Re: feather 32u4 programmer not responding
when you double click the reset button do you get the red led pulsing and the bootloader COM port to appear? can you post a photo of your board?
