Feather accelerometer, RF transmitter, data logging project.
Re: Feather accelerometer, RF transmitter, data logging proj
by adafruit_support_bill on Fri Jan 04, 2019 3:58 pm
That is a GPIO pin that is being used as the CS pin for talking to the on-board RFM. You need to choose another GPIO pin to use as a CS pin for talking to the FRAM.
by wahleworld on Fri Jan 04, 2019 11:51 pm
Bill:
Thank you for answering my questions, I greatly appreciate you taking the time to respond. Despite you providing me with most of the necessary info earlier on in our discussion, I seemed to have asked similar questions time and time again. I just wanted to say thank you for your patience, and guidance.
wahleworld
by adafruit_support_bill on Sat Jan 05, 2019 8:15 am
No problem. That is what we are here for. :)
by wahleworld on Wed Jan 30, 2019 12:36 am
Hello:
I'm beginning to set up the two pairs of Feather M0 RFM69HCWs I have to communicate with each other. And I'm slowly reading through the product overview in order to ensure I understand what is happening while initiating the example code for client/server.
Currently I'm wondering what this bit of code does?
// Singleton instance of the radio driver
RH_RF69 rf69;
//RH_RF69 rf69(15, 16); // For RF69 on PJRC breakout board with Teensy 3.1
wahleworld
by wahleworld on Wed Jan 30, 2019 12:47 am
Also wondering if I should be using the reliable datagram to start with or just the simple server/client?
I'm guessing the server/client non-datagram examples would technically consume less power?
What's the best way to reduce power consumption while actively listening for an incoming transmission from the client?
wahleworld
by adafruit_support_bill on Wed Jan 30, 2019 7:10 am
RH_RF69 rf69;
That declares an instance of the RH_RF69 radio driver called "rf69". rf69 is used later in the code for communication over the radio module.
Not sure about how to do that with these particular modules. I'll check with one of our RF experts.
by wahleworld on Wed Jan 30, 2019 12:51 pm
I'm having issues with compiling my code:
perhaps you can notice something I'm not?
#include <SPI.h>
#include <RH_RF69.h>
#define RF69_FREQ 915.0
#if defined (ADAFRUIT_SAMD_FEATHER_M0) // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
RH_RF69 rf69(RFM69_CS, RFM69_INT);
void setup()
  Serial.begin(115200);
  //while (!Serial) { delay(1); } // wait until serial console is open, remove if not tethered to computer
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 RX Test!");
  Serial.println();
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
voidsetup()
  Serial.begin(9600);
  if (!rf69.init())
    Serial.println("init failed");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ))
    Serial.println("setFrequency failed");
  // If you are using a high power RF69, you *must* set a Tx power in the
  // range 14 to 20 like this:
  // rf69.setTxPower(14);
 // The encryption key has to be the same as the one in the client
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  rf69.setEncryptionKey(key);
#if 0
  // For compat with RFM69 Struct_send
  rf69.setModemConfig(RH_RF69::GFSK_Rb250Fd250);
  rf69.setPreambleLength(3);
  uint8_t syncwords[] = { 0x2d, 0x64 };
  rf69.setSyncWords(syncwords, sizeof(syncwords));
  rf69.setEncryptionKey((uint8_t*)"thisIsEncryptKey");
#endif
void loop()
  if (rf69.available())
    // Should be a message for us now
    uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
    uint8_t len = sizeof(buf);
    if (rf69.recv(buf, &len))
//      RH_RF69::printBuffer("request: ", buf, len);
      Serial.print("got request: ");
      Serial.println((char*)buf);
//      Serial.print("RSSI: ");
//      Serial.println(rf69.lastRssi(), DEC);
      // Send a reply
      uint8_t data[] = "And hello back to you";
      rf69.send(data, sizeof(data));
      rf69.waitPacketSent();
      Serial.println("Sent a reply");
    else
      Serial.println("recv failed");
I will mention again that I'm not an experienced coder. I'm using the server example included in the radiohead library, and following along with an example.. Just wondering if you have any tips!
Thank you!
wahleworld
by wahleworld on Wed Jan 30, 2019 12:59 pm
Okay, I may be onto something..
When calling a pin for pinmode, I should be using the number to call the pin?
based on how I defined them here:
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
pinMode(13, OUTPUT);
vs.
wahleworld
by adafruit2 on Wed Jan 30, 2019 12:59 pm
"What's the best way to reduce power consumption while actively listening for an incoming transmission from the client?"
there isnt really - active listening will take power. but not as much as transmission. the only way to really gauge power is with a power monitor, there's no way to know with just software
adafruit2
Site Admin
by wahleworld on Wed Jan 30, 2019 1:18 pm
Thanks..
Now, moving onto the coding.
wahleworld
by wahleworld on Wed Jan 30, 2019 1:49 pm
I seem to have alleviated several error messages from my intitial code, but am now running into an error that I am unsure of how to deal with.
#include <SPI.h>
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
RH_RF69 rf69(8, 3);
void setup()
  pinMode(4, OUTPUT);
  digitalWrite(4, LOW);
  Serial.println();
  // manual reset
  digitalWrite(4, HIGH);
  delay(10);
  delay(10);
void setup()
  Serial.begin(9600);
  if (!rf69.init())
  // No encryption
#if 0
#endif
void loop()
      // Send a reply
    else
Error returns "a function-definition is not allowed here before "{" token"
I'm currently reviewing other online sources, but also wanted to reach out here.
Thanks in advance
wahleworld
by adafruit_support_bill on Wed Jan 30, 2019 2:22 pm
Looks like you are trying to define a second 'setup()' function - starting in the middle of the first one.
by wahleworld on Wed Jan 30, 2019 4:09 pm
I've simply copied/pasted an example code and am running into numerous errors.
I've followed the example from the product overview, which is different from the examples in the radiohead library, and still cannot get the code to compile..
// rf69_server.pde
// -*- mode: C++ -*-
#include <SPI.h>
#if defined (ADAFRUIT_FEATHER_M0) // Feather M0 w/Radio
  #define RFM69_CS      8
  #define RFM69_INT     3
  #define RFM69_RST     4
  #define LED           13
#endif
//RH_RF69 rf69(8, 3);
  pinMode(4, OUTPUT);
  Serial.println();
  // manual reset
  delay(10);
  delay(10);
#if 0
#endif
void loop()
      // Send a reply
    else
Can you offer any suggestions to help with the debugging process?
wahleworld
by adafruit_support_bill on Wed Jan 30, 2019 4:23 pm
You now have your #includes inside your setup() function. And a bunch of code between your setup() and your loop() that is not associated with any function at all.
You can't just paste random bits of code anywhere. Programs need to adhere to the rules of the language. The curly braces { } define the scope of functions and blocks of code.. For every '{' you need a matching '}'.
http://www.cplusplus.com/doc/tutorial/functions/
by wahleworld on Wed Jan 30, 2019 4:51 pm
I've tried to follow along with other examples, and have ran into countless errors.
I will start over, again, and get back to you..
So I should have my void setup() function below the libraries included?
wahleworld
