Any ideas what the feather is doing? I would expect that when I save the python file it would abort the existing script and start running the new file right away. Is this because Windows 10 is not writing the entire file out and it takes 25 seconds to flush the file? If yes then is there a trick to flush the file?
Here is the output of the code:
- Code: Select all | TOGGLE FULL SIZE
I save the python file to the feather
ReloadException:
soft reboot
code.py output:
Start of Init
End of Init
Sits here for 25 or so seconds and then the code reloads again without any user actions
soft reboot
code.py output:
Start of Init
End of Init
Before true
Here is the code that I am running:
import time
import board
import neopixel
# On CircuitPlayground Express, and boards with built in status NeoPixel -> board.NEOPIXEL
# Otherwise choose an open pin connected to the Data In of the NeoPixel strip, i.e. board.D1
#pixel_pin = board.NEOPIXEL
pixel_pin = board.D10
# On a Raspberry pi, use this instead, not all pins are supported
#pixel_pin = board.D18
# The number of NeoPixels
#num_pixels = 10
num_pixels = 24
# The order of the pixel colors - RGB or GRB. Some NeoPixels have red and green reversed!
# For RGBW NeoPixels, simply change the ORDER to RGBW or GRBW.
ORDER = neopixel.GRB
print("Start of Init")
pixels = neopixel.NeoPixel(pixel_pin, num_pixels, brightness=0.2, auto_write=False,
pixel_order=ORDER)
print("End of Init")
def wheel(pos):
# Input a value 0 to 255 to get a color value.
# The colours are a transition r - g - b - back to r.
# print(pos)
if pos < 0 or pos > 255:
r = g = b = 0
elif pos < 85:
r = int(pos * 3)
g = int(255 - pos*3)
b = 0
elif pos < 170:
pos -= 85
r = int(255 - pos*3)
g = 0
b = int(pos*3)
else:
pos -= 170
r = 0
g = int(pos*3)
b = int(255 - pos*3)
return (r, g, b) if ORDER == neopixel.RGB or ORDER == neopixel.GRB else (r, g, b, 0)
def rainbow_cycle(wait):
for j in range(255):
for i in range(num_pixels):
pixel_index = (i * 256 // num_pixels) + j
pixels[i] = wheel(pixel_index & 255)
pixels.show()
time.sleep(wait)
print("Before true")
while True:
# Comment this line out if you have RGBW/GRBW NeoPixels
pixels.fill((255, 0, 0))
# Uncomment this line if you have RGBW/GRBW NeoPixels
# pixels.fill((255, 0, 0, 0))
pixels.show()
time.sleep(1)
pixels.fill((0, 255, 0))
# pixels.fill((0, 255, 0, 0))
pixels.show()
time.sleep(1)
pixels.fill((0, 0, 255))
# pixels.fill((0, 0, 255, 0))
pixels.show()
time.sleep(1)
rainbow_cycle(0.01) # rainbow cycle with 1ms delay per step
