Adafruit Mini Color TFT with Joystick FeatherWing and partic
by jimbol on Sun Jan 13, 2019 6:54 pm
I'm trying to get this display to work with a Particle Argon.
I have the example code built successfully, but the following line returns false:
if(!ss.begin(0x49))
I cannot get seesaw to begin.
Is this the right address?
Has anyone else made this display work with a Particle Mesh device?
jimbol
Re: Adafruit Mini Color TFT with Joystick FeatherWing and pa
by jimbol on Sun Jan 27, 2019 5:40 pm
Can I have someone from support assist me please?
I have this FeatherWing, but have never been able to get it to respond at all.
When I run I2c search code, it does not find any connected device. If I plug in another featherwing (
Assembled Adafruit FeatherWing OLED - 128x32 OLED Add-on For Feather) It finds it no problem.
I suspect that this is a faulty unit, but would like some assistance to determine if this is correct.
Thanks,
Jim
jimbol
by franklin97355 on Sun Jan 27, 2019 6:33 pm
Which example code are you running and how do you have the display connected to the Argon?
franklin97355
by jimbol on Mon Feb 04, 2019 11:04 am
I've tried using the: 2-tft-basic.cpp or 3-tft-graphicstest.ino files from the Particle IDE.
The display is connected by a FeatherWing tripler which works well with other accessories I've tried.
I have also loaded I2Cscan code below, which returns the address of another display(prod 4019) if I plug it in, but doesn't show any connected I2C device if I plug in the Adafruit Mini Color TFT with Joystick FeatherWing - I think I should see the I2c address of the Seesaw...
Thanks,
Jim
#include "application.h"
void setup()
  Wire.begin();
  while (!Serial);             // Leonardo: wait for serial monitor
  Serial.println("\nI2C Scanner");
void loop()
  byte error, address;
  int nDevices;
  Serial.println("Scanning...");
  nDevices = 0;
  for(address = 1; address < 127; address++ )
    // The i2c_scanner uses the return value of
    // the Write.endTransmisstion to see if
    // a device did acknowledge to the address.
    Wire.beginTransmission(address);
    error = Wire.endTransmission();
    if (error == 0)
      Serial.print("I2C device found at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.print(address,HEX);
      Serial.println("  !");
      nDevices++;
    else if (error==4)
      Serial.print("Unknow error at address 0x");
      if (address<16)
        Serial.print("0");
      Serial.println(address,HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found\n");
  else
    Serial.println("done\n");
  delay(5000);           // wait 5 seconds for next scan
jimbol
by giounibs on Thu Feb 07, 2019 9:55 am
I bought 10 display "mini-tft with joystick" and have the same issue with 10 "Adafruit Bluefruit 32u4":
"seesaw init error"
I'm following the documentation here: https://learn.adafruit.com/adafruit-min ... duino-code
Example used is the the one mentioned in doc: "miniTFTwing -> graphictest"
Please, I need support
giounibs
by jimbol on Fri Feb 08, 2019 2:46 pm
PING,
any feedback on getting this to work or replaced? No I2C found....thx
jimbol
by adafruit2 on Fri Feb 08, 2019 3:55 pm
hiya the Particle feathers need different drivers right? our libraries are for Arduino IDE board & particle uses the Particle IDE?
you may want to ask Particle if they can 'port' the library to their IDE!
adafruit2
Site Admin
by jimbol on Fri Feb 08, 2019 4:46 pm
They have ported a library for this device, and that's the library I'm using.
It is confirmed to work with this board, which is why I'm here with this query.
I expect that I should be able to see the Seesaw chip on I2c, but cannot. I believe that the board is faulty, but want to get some assistance from Adafruit to determine if this is the case.
jimbol
by adafruit2 on Fri Feb 08, 2019 4:50 pm
well, first thing to check - does it work with a non-particle feather? cause its unlikely its not working - and we test with an atmega feather!
adafruit2
Site Admin
by jimbol on Fri Feb 08, 2019 4:56 pm
Thanks for the reply.
I don't have any non-particle feathers, so I cannot check this.
I use other adafruit feathering displays, for example this one:
https://www.adafruit.com/product/3045
If I plug it in, I can run I2c search code to find the I2c address. Shouldn't I be able to do the same with this?? :
https://www.adafruit.com/product/3321
jimbol
by adafruit2 on Fri Feb 08, 2019 5:33 pm
do you have any other non-particle devices? its just odd that it doesnt appear - it can happen but checking i2c with something else would be wise!
if you have nothin' or still cant identify it - email support@adafruit for a new wing
adafruit2
Site Admin
cron
