Bluefruit nRF52 Servo Detach
by NMolargik on Sat Jan 19, 2019 6:30 pm
Having some issues with servos on the Bluefruit nRF52 Feather board. Using the standard Arduino Servo.h library, all functions seem to work except servo.detach();. I made sure I am using it in the right syntax, but the servo continues to jitter at the position it was last sent instead of detaching. Tested with an Arduino Uno, the servo detaches fine. Please help.
Thank you!
I have since updated the board to 0.9.3 and the Servo.h library to 1.1.3 and now i get a compiler error and can't even upload my code.
Arduino: 1.8.7 (Windows 10), Board: "Adafruit Bluefruit nRF52832 Feather, 0.2.5 (s132 6.1.1), Level 0 (Release)"
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:24: error: 'NRF_PWM_CHANNEL_COUNT' was not declared in this scope
 uint32_t group_pins[3][NRF_PWM_CHANNEL_COUNT]={{NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED}, {NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED}, {NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED, NRF_PWM_PIN_NOT_CONNECTED}};
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:49: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:76: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:103: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:130: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:159: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:186: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:213: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:240: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:269: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:296: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:323: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:31:350: error: 'NRF_PWM_PIN_NOT_CONNECTED' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:32:31: error: 'NRF_PWM_CHANNEL_COUNT' was not declared in this scope
 static uint16_t seq_values[3][NRF_PWM_CHANNEL_COUNT]={{0, 0, 0, 0}, {0, 0, 0, 0}, {0, 0, 0, 0}};
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp: In member function 'void Servo::writeMicroseconds(int)':
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:92:12: error: 'g_APinDescription' was not declared in this scope
  instance=(g_APinDescription[pin].ulPWMChannel & 0xF0)/16;
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:95:2: error: 'group_pins' was not declared in this scope
  group_pins[instance][channel]=g_APinDescription[pin].ulPin;
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:98:2: error: 'seq_values' was not declared in this scope
  seq_values[instance][channel]= value | 0x8000;
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:99:2: error: 'nrf_pwm_sequence_t' was not declared in this scope
  nrf_pwm_sequence_t const seq={
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:105:52: error: 'nrf_pwm_pins_set' was not declared in this scope
  nrf_pwm_pins_set(PWMInstance, group_pins[instance]);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:106:28: error: 'nrf_pwm_enable' was not declared in this scope
  nrf_pwm_enable(PWMInstance);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:107:33: error: 'NRF_PWM_CLK_125kHz' was not declared in this scope
  nrf_pwm_configure(PWMInstance, NRF_PWM_CLK_125kHz, NRF_PWM_MODE_UP, 2500); // 20ms - 50Hz
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:107:53: error: 'NRF_PWM_MODE_UP' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:107:74: error: 'nrf_pwm_configure' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:108:35: error: 'NRF_PWM_LOAD_INDIVIDUAL' was not declared in this scope
  nrf_pwm_decoder_set(PWMInstance, NRF_PWM_LOAD_INDIVIDUAL, NRF_PWM_STEP_AUTO);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:108:60: error: 'NRF_PWM_STEP_AUTO' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:108:77: error: 'nrf_pwm_decoder_set' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:109:40: error: 'seq' was not declared in this scope
  nrf_pwm_sequence_set(PWMInstance, 0, &seq);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:109:43: error: 'nrf_pwm_sequence_set' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:110:35: error: 'nrf_pwm_loop_set' was not declared in this scope
  nrf_pwm_loop_set(PWMInstance, 0UL);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:111:36: error: 'NRF_PWM_TASK_SEQSTART0' was not declared in this scope
  nrf_pwm_task_trigger(PWMInstance, NRF_PWM_TASK_SEQSTART0);
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:111:58: error: 'nrf_pwm_task_trigger' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp: In member function 'int Servo::readMicroseconds()':
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:123:12: error: 'g_APinDescription' was not declared in this scope
C:\Users\nmola\Documents\Arduino\libraries\Servo\src\nrf52\Servo.cpp:126:9: error: 'seq_values' was not declared in this scope
  return seq_values[instance][channel] & 0x7FFF;
exit status 1
Error compiling for board Adafruit Bluefruit nRF52832 Feather.
NMolargik
Re: Bluefruit nRF52 Servo Detach
by hathach on Mon Jan 21, 2019 2:32 am
you are compiling with standard Servo library, BSP come with its own Servo lib. Please remove the one you installed and re-compile again.
Update: We have update the BSP master branch to fix the Servo detach issue
https://github.com/adafruit/Adafruit_nRF52_Arduino
Please clone/download code from github to see if that works for you.
hathach
by NMolargik on Mon Jan 21, 2019 3:29 pm
That definitely works! Thank you!
NMolargik
