Feather M0 Wifi - Cannot connect to Adafruit IO
by marsicop on Mon Jan 28, 2019 10:59 am
I have a Feather M0 model (3044) and am experiencing a problem while trying to run the simple "servo" example posted in the Adafruit IO Learn section. I have confirmed / re-entered my IO credentials several times, as well as my network access credentials. I have also checked/updated firmware & SSL certificates, as per the earlier advice in related/similar threads. I can get the "Simple Wifi Client" example to run ... so I'm pretty sure that the Feather is able to connect to my network.
I'm a newbie ... on hour #3 of trying to figure out the IO connection problem ... wouldn't turn down any help / suggestions. :-)
Also, in case it is helpful ... I inserted a few debug serial.print lines in the example code (below), as well as a screenshot of the corresponding console. Doesn't appear to make it inside the while loop?? ... just hangs.
Thanks in advance for assistance / advice.
- Peter
****** modified sketch code **********************************
// connect to io.adafruit.com
Serial.println("(1) Calling io.connect ");
io.connect();
Serial.print("(2) This is the AIO_CONNECTED value: ");
Serial.println(AIO_CONNECTED);
// set up a message handler for the 'servo' feed.
// the handleMessage function (defined below)
// will be called whenever a message is
// received from adafruit io.
servo_feed->onMessage(handleMessage);
Serial.print("(3) Before WAIT loop ... io.status = ");
Serial.println(io.statusText());
// wait for a connection
while(io.status() < AIO_CONNECTED) {
Serial.print("(4) Waiting in loop io.status = ");
delay(500);
******** Corresponding console output *******************
AdafruitIO::connect()
(2) This is the AIO_CONNECTED value: 21
(3) Before WAIT loop ... io.status = Idle. Waiting for connect to be called...
marsicop
Re: Feather M0 Wifi - Cannot connect to Adafruit IO
by adafruit_support_carter on Mon Jan 28, 2019 1:54 pm
Try working with a more simple example and see if you get the same issue. Try the basic digital example:
https://learn.adafruit.com/adafruit-io- ... ital-input
by marsicop on Sun Feb 03, 2019 10:39 pm
Finally got a chance to give your advice a try ... and the simpler example worked fine. Not sure what I was doing wrong in the Servo Example, but am on the way to figuring it out.
Thanks very much for the assistance.
marsicop
by marsicop on Wed Feb 06, 2019 6:45 pm
Back to the IO Basics Servo example @ IO.
Same problem. I'm running the vanilla 16_Servo example sketch code. No substantial changes (just added a few extra print lines to try to figure out why it hangs. Get the same behavior that I described in the original post. (The IO & Wifi credential information in the config.h file is identical to that in the simpler digital example that you pointed me to earlier). I can also see that the Feather shows up as a connected device on my Wifi when I run the 06_Digital In example, ... but never shows up when I run the 16_Servo example. Any additional thoughts / advice?
Thanks in advance for the assistance.
marsicop
by adafruit_support_carter on Thu Feb 07, 2019 12:11 am
AIO_CONNECTED is just a constant:
https://github.com/adafruit/Adafruit_IO ... ons.h#L100
so printing that will just print 21 everytime. To check the status of the connection, add a call to status() after connect():
  io.connect();
  Serial.print("Status = "); Serial.println(io.status());
See what that returns. You can compare to the values linked above.
by marsicop on Tue Feb 12, 2019 6:45 pm
Added your println statements. Same behavior as originally seen. Makes a call to io.connect and then hangs. Here is the serial monitor output:
17:32:59.317 -> (1) Calling io.connect
17:32:59.317 -> AdafruitIO::connect()
17:33:04.234 -> Status =
Again, it makes the io.connect call successfully in the "06 digital in" example sketch.
Is it possibly a home firewall/router issue? ... or would that make no sense?
marsicop
by adafruit_support_carter on Wed Feb 13, 2019 3:43 pm
It printed nothing for the actual status code?
by marsicop on Wed Feb 13, 2019 4:04 pm
nothing ... just hangs (forever)
marsicop
by adafruit_support_carter on Wed Feb 13, 2019 4:44 pm
It's acting like the call to status() is hanging. But that get's used a lot internally. It's off that the basic example works, but this doesn't. When you hit this issue, can you go back to the example that worked and it still works?
