Adafruit feather with LiPo and 5-6V servo
by pathead on Mon Feb 11, 2019 10:44 pm
I am making a remote controlled door lock and want to be able to have a battery backup. My original idea was to use a feather huzzah running off micro-usb power with a 3.7V lipo battery as backup and a 3.7V to 5V boost module to power the motor but it seems the feather huzzah is unable to drive the MG995R (https://www.adafruit.com/product/1142) even when on USB power.
I noticed there were servo boards for the feather but they state that running servo's off the LiPo battery is not recommended. Is there any other way to accomplish what I am trying to do without using some complex switching mechanism to detect a loss of USB power and switch to a separate battery pack?
pathead
Re: Adafruit feather with LiPo and 5-6V servo
by adafruit_support_bill on Tue Feb 12, 2019 7:02 am
Some servos do not respond reliably to a 3.3v control signal such as the one from the Huzzah and other Feather boards. You may need to do some voltage level shifting to get a 5v control signal:
https://www.adafruit.com/product/1875
https://www.adafruit.com/product/735
by pathead on Tue Feb 12, 2019 8:04 pm
That didn't seem to work... I used a sparkfun level shifter (https://www.sparkfun.com/products/12009) I had and the behavior didn't change. The motor makes a soft stuttering sound but doesn't move.
pathead
by adafruit_support_bill on Tue Feb 12, 2019 8:31 pm
Please post some photos showing all of your soldering and connections.
by jdelcamp11 on Wed Feb 13, 2019 7:00 pm
I am using the feather M0 with the pwm servo wing. driving 2 servos and an RGB on the pwm board.
I added a power boost basic (input from the battery pin, output to the pwm power connector)
This works well for me.
jdelcamp11
by pathead on Tue Feb 19, 2019 8:26 pm
Quick question... do you have the LiPo battery connected to the power boost basic with the 5v output connected to the power input on the servo wing? i.e. to here: https://learn.adafruit.com/assets/33098 ?
Or do you have the LiPo battery connected to the feather with the 3V output from the feather connected to the power input on the power boost?
pathead
by pathead on Wed Feb 20, 2019 9:52 pm
Nevermind I figured it out.
Thanks for the help jdelcamp11!
pathead
