Featherboards stuck uploading
by Instance on Tue Feb 12, 2019 1:07 am
I just bought two Featherboards (a Basic Proto and an Express). I followed the instructions outlined here:
https://learn.adafruit.com/adafruit-fea ... rduino-ide
The board package and drivers installed just fine and I can connect to via the Arduino IDE. However, when I try to upload it gets stuck and endlessly says 'Uploading' (see attached image).
I tried double-pressing the RST button to get back into the bootloader ... but it doesn't do anything different. I have a fresh install of Win 10 and tried re-installing the drivers and restarting several times. Always the same result, sometimes it will end with the error message below. Note that if I connect an Arduino Due and change the board type using the same USB cable and instance of the IDE it will upload fine to the Due ... but if I change the board type back to Featherboard 32u4 and connect it then it gets stuck on 'Uploading' again. Any help appreciated!
Copied error message:
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Adafruit Feather 32u4"
Build options changed, rebuilding all
Sketch uses 4052 bytes (14%) of program storage space. Maximum is 28672 bytes.
Global variables use 149 bytes of dynamic memory.
avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = "þ"; type = ¸
Software Version = i.
Instance
Re: Featherboards stuck uploading
by franklin97355 on Tue Feb 12, 2019 4:06 am
Can you post pictures of the two boards? Both sides. Are you sure you are using the correct board file when uploading?
franklin97355
by Instance on Tue Feb 12, 2019 11:17 pm
See images attached and list of boards available. I tried both boards listed with 'Feather' in the name, should it be one of the others? Or is the correct board missing from the list?
Instance
by franklin97355 on Tue Feb 12, 2019 11:53 pm
You have a Feather M0 and a Feather M0 Express but you are trying to compile and upload to a Feather 32u4. That is not going to work. The Feather M0 is in the Adafruit SAMD boards section. Make sure you have both the Arduino SAMD and the Adafruit SAMD board files installed in the Board Manager.
franklin97355
by Instance on Wed Feb 13, 2019 12:10 am
Got it -- I followed the tutorial too literally. Thanks for the help!
Instance
