Feather M4 Express and WavFilePlayerCircuitpythonFS
by Casey10110 on Fri Feb 15, 2019 12:57 am
Hi Guys,
I've got files uploaded via Circuit Python to the flash memory and, testing with the WavFilePlayerCircuitpythonFS in the Adafruit Audio library, it says that it is playing the files, but I can't hear anything. I suspect it is because the I2S is not configured properly.
With the tone_generator example from the Adafruit Zero I2S library, I use
Adafruit_ZeroI2S i2s(10, 11, 1, 2);
and it works fine, but when I upload the WavFilePlayerCircuitpythonFS file, I can't hear anything.
How can I configure this WavFilePlayerCircuitpythonFS example to work on the same pins? Any ideas?
UPDATE: I tried this edit in the output_i2s.cpp file in the Audio library and it still doesn't work:
void AudioOutputI2S::begin(void)
#if defined(__SAMD51__)
   i2s = new Adafruit_ZeroI2S(10, 11, 1, 2);
   dma = new Adafruit_ZeroDMA;
Thank you!
Casey
Casey10110
Re: Feather M4 Express and WavFilePlayerCircuitpythonFS
by Casey10110 on Fri Feb 15, 2019 3:57 pm
Does WavFilePlayerCircuitpythonFS even using i2s? LOL.
Casey10110
by adafruit_support_carter on Fri Feb 15, 2019 6:20 pm
Can you link to the example or guide you are trying to follow.
by Casey10110 on Fri Feb 15, 2019 7:16 pm
Casey10110
by adafruit_support_carter on Fri Feb 15, 2019 8:10 pm
by Casey10110 on Fri Feb 15, 2019 8:33 pm
Dude. THANK YOU. Simply replace this line:
AudioOutputAnalogStereo  audioOutput;
with this:
AudioOutputI2S  audioOutput;
For me, I also had to change
   i2s = new Adafruit_ZeroI2S;
to
   i2s = new Adafruit_ZeroI2S(10,11,1,2);
in the output_i2s.cpp ...
Casey10110
