esp32 feather fails with SPI TFT featherwing
by klankschap on Fri Feb 15, 2019 1:00 pm
The default examples of the TFT featherwing fail to compile with the ESP32 feather wing.
/Arduino/libraries/Adafruit_HX8357_Library/Adafruit_HX8357.cpp:112:25: error: '_spi' was not declared in this scope
#define SPI_OBJECT _spi ///< Default SPI hardware peripheral
Using library SPI at version 1.0 in folder: /Arduino/hardware/espressif/esp32/libraries/SPI
Using library Adafruit_GFX_Library at version 1.3.6 in folder: /Arduino/libraries/Adafruit_GFX_Library
Using library Adafruit_HX8357_Library at version 1.0.7 in folder: /Arduino/libraries/Adafruit_HX8357_Library
exit status 1
Error compiling for board Adafruit ESP32 Feather.
Howto proceed ?
klankschap
Re: esp32 feather fails with SPI TFT featherwing
by adafruit_support_carter on Fri Feb 15, 2019 7:30 pm
It looks like that library has some updates that have not been released yet. I got it to compile by going in to the existing release version and editing this line:
to this:
 #define SPI_OBJECT SPI ///< Default SPI hardware peripheral
You should be able to find that file in {YOUR SKETCH FOLDER}/libraries/Adafruit_HX8357_Library/Adafruit_HX8357.cpp
by adafruit2 on Sat Feb 16, 2019 3:46 pm
Try v1.1.0 just released
adafruit2
Site Admin
by klankschap on Sat Feb 16, 2019 3:52 pm
the code correction _spi into SPI made it work.
klankschap
