There may some shipping delays at this time, orders placed on Fri Jan 22, may not ship for 1-2 business days.
ESP 32 Huzzah feather battery switch
by scotech on Wed Mar 27, 2019 12:55 am
I have a project that requires an on off switch to shut the ESP 32 feather battery off whilst plugged in to the battery jack. I need to be able to charge the battery while the switch is in the off position, how can I do this as well as run an LED only when charging the battery with the USB port.
I would like to use a 3.7v 2600 ma Li-ion battery, is there likely to be any issues charging it with the on board charger?
scotech
Re: ESP 32 Huzzah feather battery switch
by adafruit_support_carter on Wed Mar 27, 2019 3:19 pm
Sounds like you could use the EN pin:
https://learn.adafruit.com/adafruit-huz ... r-pins-2-4
which will turn off the 3.3V regulator which is the power for the ESP32. Batter charging runs off VBUS, so would still work.
by TopHatRaver on Wed Aug 21, 2019 8:52 am
I have wired up a Huzzah to some LEDs with a power Switch as noted in these instructions but I have a couple of questions:
1) Is there a way of increasing the charge rate to greater than 100mA? I'm using a 2000mAh battery and it takes a long time to charge it.
2) The light always seems to stay on when charging. I expected it to turn off once the battery was full. Is that incorrect?
Appreciate your help!
TIM
Huzzah Wiring.PNG (182.77 KiB) Viewed 73 times
TopHatRaver
by adafruit_support_carter on Wed Aug 21, 2019 11:39 am
@TopHatRaver Please start a new thread for your issue.
by TopHatRaver on Thu Aug 22, 2019 2:42 pm
adafruit_support_carter wrote:@TopHatRaver Please start a new thread for your issue.
@adafruit_support_carter Ok I created a new post here
https://forums.adafruit.com/viewtopic.php?f=57&t=155514
TopHatRaver
