Does anyone know where the sketch for bluetooth neopixel module is? I want to control a neopixel featherwing, but can't find it.
I'm not looking for this one: https://github.com/adafruit/Adafruit_Bl ... xel_picker
It's the once that you can set the grid size.
Sketch for Neopixel Bluetooth app
- oesterle
Re: Sketch for Neopixel Bluetooth app
Hi, justinmy!
Theres a neomatrix example that works with the nRF52 Feathers: If you have the board support package for those boards installed, it's in:
File > Examples > Adafruit Bluefruit nRF52 Libraries > Peripheral > neomatrix
It's also on GitHub: adafruit/Adafruit_nRF52_Arduino… neomatrix
It will need a little modification if you're working with a different Bluetooth LE chip/library, like an nRF51 or nRF8001.
Which BLE are you using?
Cheers,
Eric
Cheers,
Eric
- justmobilize
Ahhh, I'm using the nRF51, since I have a bunch of them.
Is there anything stopping it from being ported? Other then time?
- oesterle
Yeah, likely time and an enthusiastic contributor. Maybe you can get it working, and submit a pull request!
Come back here if you get stuck.
- justmobilize
Already started working on it. I can get the `commandVersion` call to succeed, but even though the Android app should be sending a `commandSetup` command, it never does.
- justmobilize
Nevermind. Figured it out. Had grabbed other code that had `ble.waitForOK()`. Took that out and moving along
- justmobilize
