Anyways, I'm working with the nrf52832 and ultimately am hoping to use it in tandem with a custom iOS app for logging user data. My first issue is that I haven't been able to figure out how to get the board advertise such that it's visible within the iOS bluetooth settings and able to pair (or bond) from there. I can connect through various companion apps (Bluefruit, LightBlue) but always with those apps, the connection is broken anytime the app is closed and must be manually created once again each time the app is re-opened.
I'm hoping for some guidance regarding how I might go about having the board advertise such that a bond can be created. If not being done through iOS settings, is this a connection event that I can specify from the server side, or is it driven by the client and so I'd need to have the code of the app written to facilitate that?
The BLEHID class allows bonding through the iOS settings in this way. But I have not been successful in trimming the BLEHID example code in such a way that I can have my board bond through iOS settings without the HIDKeyboard part actually being initiated. https://learn.adafruit.com/bluefruit-nr ... idadafruit
If anyone could advise on this or point me in the right direction, I would be extremely grateful. Thanks!
In case relevant or of interest, below is the advertising code I have at the moment:
Advertising code:
void startAdv(void)
// Advertising packet
Bluefruit.Advertising.addFlags(BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE);
Bluefruit.Advertising.addTxPower();
// Include HRM Service UUID
Bluefruit.Advertising.addService(isvs);
// Include Name
Bluefruit.Advertising.addName();
/* Start Advertising
- Enable auto advertising if disconnected
- Interval: fast mode = 20 ms, slow mode = 152.5 ms
- Timeout for fast mode is 30 seconds
- Start(timeout) with timeout = 0 will advertise forever (until connected)
For recommended advertising interval
https://developer.apple.com/library/content/qa/qa1931/_index.html
Bluefruit.Advertising.restartOnDisconnect(true);
Bluefruit.Advertising.setInterval(32, 244); // in unit of 0.625 ms
Bluefruit.Advertising.setFastTimeout(30); // number of seconds in fast mode
Bluefruit.Advertising.start(0); // 0 = Don't stop advertising after n seconds
#include <bluefruit.h>
#include "Adafruit_VL53L0X.h"
Adafruit_VL53L0X lox = Adafruit_VL53L0X();
// MYSERVICE_UUID: 67C57C9D-08E3-4AFE-886D-5058D5983F1B, written as an array in little endian
const uint8_t MYSERVICE_UUID[] =
0x1B, 0x3F, 0x98, 0xD5, 0x58, 0x50, 0x6D, 0x88,
0xFE, 0x4A, 0xE3, 0x08, 0x9D, 0x7C, 0xC5, 0x67
// MYCHR_UUID: 67C57C9D-08E3-4AFE-886D-5058D5983F1C, written as an array in little endian
const uint8_t MYCHR_UUID[] =
0x1C, 0x3F, 0x98, 0xD5, 0x58, 0x50, 0x6D, 0x88,
byte Count = 0;
int New_Max;
int Volume;
BLEService isvs(MYSERVICE_UUID); // Custom IS Volume Service
BLECharacteristic isvc(MYCHR_UUID); // Custom IS Volume Characteristic
BLEHidAdafruit blehid;
BLEDis bledis; // DIS (Device Information Service) helper class instance
// Advanced function prototypes
void startAdv(void);
void setupVolTrack(void);
void connect_callback(uint16_t conn_handle);
void disconnect_callback(uint16_t conn_handle, uint8_t reason);
void setup()
Serial.begin(115200);
Serial.println("I.S. Trial Bluetooth");
lox.begin();
// Initialise the Bluefruit module
Serial.println("Initialise the Bluefruit nRF52 module");
Bluefruit.begin();
Bluefruit.setTxPower(4);
// Set the advertised device name (keep it short!)
Serial.println("Setting Device Name to 'IS Puck2'");
Bluefruit.setName("IS PUCK2");
// Set the connect/disconnect callback handlers
Bluefruit.setConnectCallback(connect_callback);
Bluefruit.setDisconnectCallback(disconnect_callback);
// Configure and Start the Device Information Service
Serial.println("Configuring the Device Information Service");
bledis.setManufacturer("Adafruit Industries");
bledis.setModel("Bluefruit Feather52");
bledis.begin();
// Setup the IS Volume Service service using
// BLEService and BLECharacteristic classes
Serial.println("Configuring the IS Volume Service");
setupVolTrack();
// Setup the advertising packet(s)
Serial.println("Setting up the advertising payload(s)");
startAdv();
Serial.println("Advertising");
void startAdv(void)
// Include Name
isvs.begin();
isvc.setProperties(CHR_PROPS_NOTIFY); // Setup as notify
isvc.setPermission(SECMODE_OPEN, SECMODE_NO_ACCESS); // First value sets read permissions, second write
isvc.setFixedLen(2); // Indicates how many bytes the characteristic has. Can be 1-20 for 'notify'.
isvc.setCccdWriteCallback(cccd_callback); // Optionally capture CCCD updates
isvc.begin();
isvc.notify32(Volume);
char central_name[32] = { 0 };
Bluefruit.Gap.getPeerName(conn_handle, central_name, sizeof(central_name));
Serial.print("Connected to ");
Serial.println(central_name);
Callback invoked when a connection is dropped
@param conn_handle connection where this event happens
@param reason is a BLE_HCI_STATUS_CODE which can be found in ble_hci.h
(void) conn_handle;
(void) reason;
Serial.println("Disconnected");
Serial.println("Advertising!");
void cccd_callback(BLECharacteristic& chr, uint16_t cccd_value)
// Display the raw request packet
Serial.print("CCCD Updated: ");
//Serial.printBuffer(request->data, request->len);
Serial.print(cccd_value);
Serial.println("");
// Check the characteristic this CCCD update is associated with in case
// this handler is used for multiple CCCD records.
if (chr.uuid == isvc.uuid) {
if (chr.notifyEnabled()) {
Serial.println("Volume measurement 'Notify' enabled");
} else {
Serial.println("Volume measurement 'Notify' disabled");
void loop()
digitalToggle(LED_RED);
VL53L0X_RangingMeasurementData_t measure;
lox.rangingTest(&measure, false); // pass in 'true' to get debug data printout!
if (measure.RangeStatus != 4) {
Volume = round(0.2078 * sq(measure.RangeMilliMeter) + 10.679 * measure.RangeMilliMeter - 319.4);
if (Bluefruit.connected() ) {
if (isvc.notify32(Volume)) {
Serial.print("Volume captured: "); Serial.println(Volume);
else {
Serial.println("ERROR: Notify not set in the CCCD or not connected!");
delay(1000);
