Adafruit ESP32 feather and BME680 - i2c pull up resistors
by brodseba on Tue Jun 11, 2019 11:31 pm
I'm trying to read from an BME680 sensor from an Adafruit ESP32 feather using I2C. The doc said: I2C pins do not have pull up resistors. And we must add them if we want to communicate with an I2C device.
Wiring setup
But how to decide witch resistors to use? Is it a 4.7K, 10K. Will it depend on the sensor? What am I looking for in the datasheet of the sensor? The Bosch doc seem to indicate I need to use 4.7K resistors. But I try both, 4.7K and 10K and I still getting the same error message: Could not find a valid BME680 sensor, check wiring!
Here what I try already:
  • Using Port 0x77 and 0x76
  • Using 4.7K, 10K and no pull up resistors
  • Moving the sensor on another part of the breadboard
  • Checking multiple time the wiring
  • Looking at my solder pins
I am kind of out of option here. May I have damage the sensor by not using pull up resistors the first time? How do I check if the sensor is damaged?
I may also try to use SPI instead of I2C, but not sure if it need pull resistors when using SPI instead.
brodseba
Re: Adafruit ESP32 feather and BME680 - i2c pull up resistor
by jerryn on Wed Jun 12, 2019 6:12 am
Just a few observations:
The BME680 breakout has 10K Pull-ups -- see the schematic https://learn.adafruit.com/assets/48082
The BME680 can take 3-5V as Vin, but it pulls the SDA/SCL to Vin to match the level.but so you should be powering the BME680 from 3.3V not VUSB as you have it since that will pull the SCA/SDL to 5V which is not appropriate for the ESP32.
I don't know if that would explain the problems, but it may be worth try:
Not using pull-ups should have been no problem -- the default address is 0x77 but using 5V for Vin may not be good for the ESP32 SDA/SCL pins.
from the guide: https://learn.adafruit.com/adafruit-bme680-humidity-temperature-barometic-pressure-voc-gas/pinouts
Vin - this is the power pin. Since the sensor chip uses 3 VDC, we have included a voltage regulator on board that will take 3-5VDC and safely convert it down. To power the board, give it the same power as the logic level of your microcontroller - e.g. for a 5V micro like Arduino, use 5V
jerryn
by brodseba on Thu Jun 13, 2019 1:07 am
Hum, I switch to the 3V pinout.
I also try to switch from 4.7K to 10K. (The Bosch datasheet to indicate 4.7k pull up thou: https://cdn-shop.adafruit.com/product-f ... BME680.pdf
For the I2C connection, it is recommended to use 100 nF for C1 and C2. Moreover, the value for the pull-up resistors R1 and
R2 should be based on the interface timing and the bus load; a normal value is 4.7 kΩ.
I also check all my wire for connectivity.
But I keep getting the same result.
brodseba
by adafruit_support_carter on Thu Jun 13, 2019 1:05 pm
You don't need to add any pullups. The wiring connection is shown here:
https://learn.adafruit.com/adafruit-bme ... cuitpython
Check your soldering. It looks like it might be a little thin on some of the pins.
https://learn.adafruit.com/adafruit-gui ... n-problems
