FEather(s) 32u4 shutting off after code upload
by R1racing on Wed Jun 12, 2019 5:07 pm
HI!
I have buyed 3 of the Adafruit Feather 32u4 RFM69HCW Packet Radio - 868 or 915 MHz - RadioFruit.. All of them are working right out of the box when I load the example sketch ( led blink).. but when I upload the sketch everybody is using, the boards just goes OFF.. it blinks red for a few seconds, then just shut off.. If I press the reset, its the same, few seconds, then off..NO matter if its via USB or battery, its the same..
Any ideas ?? I need the boards to finish my replica robot BB-8 .. a lot of people are using this system without problems.
I am putting here the main code and the functions so everybody can see.. Maybe someono knows why the boards( the 3 of them ) are crashing
R1racing
Re: FEather(s) 32u4 shutting off after code upload
by R1racing on Wed Jun 12, 2019 5:12 pm
  //                         Joe's Drive  - Remote "MK3"  - Updated 4/15
  //             ***         You are free to use, and share this code as long as it is not sold. There is no warranty, guarantee, or other tomfoolery.
  //                         This entire project was masterminded by an average Joe, your mileage may vary.
  //                            Written by Joe Latiola - https://www.facebook.com/groups/JoesDrive/
  //                            You will need libraries: i2cdevlib: https://github.com/jrowberg/i2cdevlib
  //                                                     Modified Low PowerLab: https://travis-ci.org/LowPowerLab/RFM69
  //                                                     EEPROM Extended: https://github.com/thijse/Arduino-EEPROMEx
  //                                                     SSD1306Ascii Text Only: https://github.com/greiman/SSD1306Ascii
   *        Find file: RFM69.h
   *        Find: #define RF69_CSMA_LIMIT_MS 1000
   *        Change to: #define RF69_CSMA_LIMIT_MS 100
  #define droidName     "BB-8"
  #define battPin       A9
  #define enablePIN     1
  #define lJoySelectPIN 13
  #define Joy2XPIN      A1
  #define Joy2YPIN      A0
  #define lBut1PIN      10
  #define lBut2PIN      11
  #define lBut3PIN      12
  #define rJoySelectPIN 0
  #define Joy1XPIN      A4
  #define Joy1YPIN      A5
  #define rBut1PIN      6
  #define rBut2PIN      5
  #define rBut3PIN      9    //   This is the only button / pin that must not change.
  #define Joy3XPIN      A3
  #define Joy4XPIN      A2
  #define dataDelay     0
  #define sendDelay     20
  #define recDelay      2
  //#define serialSound   //Uncomment this if you are using Serial3 for sounds in the body
  //#define debug
  #include <EEPROMex.h>
  #include "Arduino.h"
  #include <Wire.h>
  #include "SSD1306AsciiWire.h"
  #define I2C_ADDRESS 0x3C
  SSD1306AsciiWire oled;
  #include <RFM69.h>    //get it here: https://www.github.com/lowpowerlab/rfm69
  #include <SPI.h>
  // *********** IMPORTANT SETTINGS - YOU MUST CHANGE/CONFIGURE TO FIT YOUR HARDWARE ************
  #define NETWORKID       100  // The same on all nodes that talk to each other
  #define REMOTE_ADDRESS  1    // The unique identifier of this node
  #define BODY_ADDRESS    2    // The recipient of packets
  #define DOME_ADDRESS    3    // The recipient of packets
  #define DRIVE_ADDRESS   4
  //Match frequency to the hardware version of the radio on your Feather
  #define FREQUENCY     RF69_915MHZ
  #define IS_RFM69HCW   true // set to 'true' if you are using an RFM69HCW module
  #define SERIAL_BAUD   115200
  // for Feather 32u4 Radio
  #define RFM69_CS      8
  #define RFM69_IRQ     7
  #define RFM69_IRQN    4  // Pin 7 is IRQ 4!
  #define RFM69_RST     4
  RFM69 radio = RFM69(RFM69_CS, RFM69_IRQ, IS_RFM69HCW, RFM69_IRQN);
  #ifdef serialSound
    struct SEND_DATA_STRUCTURE{
          int Joy1Y=256; //main drive
          int Joy1X=256; //tilt / steer
          int Joy2Y=256; //head tilt
          int Joy2X=256; //head spin
          int Joy3X=256; //spin Flywheel
          int Joy4X=256;
          byte ServoMode; //Select on left joystick
          byte lBut1=0; //left 1
          byte lBut2=0; //left 2
          byte lBut3; //left3
          byte Fwd; //Select on right joystick = rJoySelect
          byte Speed;
          byte rBut2; //right 2
          byte rBut3=0; //right 3
          byte motorEnable=1; //toggle on top
          byte CalibID;
          byte wireless=1;
    }sendToBody;
  #else
        int Joy4X=256;
        byte lBut1=1; //left 1
        byte lBut2=1; //left 2
        byte lBut3; //left3
        byte Speed;
        byte rBut3=1; //right 3
        byte CalibID;
        byte wireless=1;
    }sendToBody;
    #endif
  byte packet[sizeof(sendToBody)];
  typedef struct RECEIVE_DATA_STRUCTURE_DOME{
        float bodyBatt;
        float domeBatt;
  }recDomeData;
  recDomeData recFromDome;
  typedef struct RECEIVE_DATA_STRUCTURE_BODY{
        int psi=0;
        byte button4 = 1;
        float bodyBatt;
  }recBodyData;
  recBodyData recFromBody;
  bool SEND;
  int Joy1X, Joy1Xa, Joy1Xb;
  int Joy1Y, Joy1Ya, Joy1Yb;
  int Joy2X, Joy2Xa, Joy2Xb;
  int Joy2Y, Joy2Ya, Joy2Yb;
  int Joy3X, Joy3Xa, Joy3Xb;
  int Joy4X, Joy4Xa, Joy4Xb;
  int Joy1XCenter, Joy1YCenter, Joy2XCenter, Joy2YCenter, Joy3XCenter, Joy4XCenter;
  int Joy1XLow=512, Joy1YLow=512, Joy2XLow=512, Joy2YLow=512, Joy3XLow=512, Joy4XLow=512;
  int Joy1XHigh=512, Joy1YHigh=512, Joy2XHigh=512, Joy2YHigh=512, Joy3XHigh=512, Joy4XHigh=512;
  int joyconfigX1, joyconfigY1, joyconfigX2, joyconfigY2, joyconfigX3, joyconfigX4;
  byte enable, bodyConfigStep, ServoMode, lBut1State, rBut1State;
  byte rJoySelect, domeSend;
  byte JoySelectState, ServoJoySelectState, dome180, DomeDirection;
  byte menuConfirm, Display, cursorMove, updateScreen = 1;
  byte casenum, lastcasenum = 1;
  byte start, wireless, bodyWireless;
  byte joyConfStep = 1;
  byte But1State, But2State, But1Sound, voiceSend, But2Sound, musicSend;
  int joyConfCountdown;
  byte waitTime = 5;
  String menuItems[] = {"Reverse Dome", "Dome Config", "Body Config", "Joystick Config"};
  String speedDisplay[] = {"Slow", "Medium", "Fast"};
  //int rectime[20];
  //byte rectimeloc;
  const int eepromSet = 890;
  int rBut1 = 1;
  float measuredvbat;
  unsigned long buttonTimer, menuTimeout, joyConfMillis, lastScreenUpdate, domeConfigTimeout;
  unsigned long bodyConfigMillis, domeConnectivityMillis, lastrecdata = 1000;
  unsigned long lastReading, lastLoopMillis, lastrecDataMillis, lastSend;
  unsigned long But1Millis, But2Millis;
  byte lJoySelect, lBut1=1, lBut2=1, lBut3, Fwd;
  byte Speed, rBut2, rBut3=1, motorEnable=1, lBut1Timer, lBut2Timer, rBut3Timer;
  unsigned long lBut1Millis, lBut2Millis, rBut3Millis;
  byte startup = 1;
    oled.begin(&Adafruit128x64, I2C_ADDRESS);
    oled.set400kHz();
    oled.setFont(Callibri15);
    oled.println(F("==========================="));
    oled.println(F("            Joe's Drive       "));
    Serial.begin(115200);
    pinMode (lJoySelectPIN, INPUT_PULLUP);
    pinMode (rJoySelectPIN, INPUT_PULLUP);
    pinMode (lBut1PIN, INPUT_PULLUP);
    pinMode (lBut2PIN, INPUT_PULLUP);
    pinMode (lBut3PIN, INPUT_PULLUP);
    pinMode (rBut1PIN, INPUT_PULLUP);
    pinMode (rBut2PIN, INPUT_PULLUP);
    pinMode (enablePIN, INPUT_PULLUP);
    // Hard Reset the RFM module
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, HIGH);
  delay(100);
  digitalWrite(RFM69_RST, LOW);
  delay(100);
  // Initialize radio
  radio.initialize(FREQUENCY,REMOTE_ADDRESS,NETWORKID);
  if (IS_RFM69HCW) {
    radio.setHighPower();    // Only for RFM69HCW & HW!
  radio.setPowerLevel(20); // power output ranges from 0 (5dBm) to 31 (20dBm)
    if(EEPROM.readInt(36) == eepromSet){
      Joy1XCenter = EEPROM.readInt(0);
      Joy1YCenter = EEPROM.readInt(2);
      Joy2XCenter = EEPROM.readInt(4);
      Joy2YCenter = EEPROM.readInt(6);
      Joy3XCenter = EEPROM.readInt(8);
      Joy4XCenter = EEPROM.readInt(10);
      Joy1XLow = EEPROM.readInt(12);
      Joy1XHigh = EEPROM.readInt(14);
      Joy1YLow = EEPROM.readInt(16);
      Joy1YHigh = EEPROM.readInt(18);
      Joy2XLow = EEPROM.readInt(20);
      Joy2XHigh = EEPROM.readInt(22);
      Joy2YLow = EEPROM.readInt(24);
      Joy2YHigh = EEPROM.readInt(26);
      Joy3XLow = EEPROM.readInt(28);
      Joy3XHigh = EEPROM.readInt(30);
      Joy4XLow = EEPROM.readInt(32);
      Joy4XHigh = EEPROM.readInt(34);
    }else{
      Joy1XCenter = 512;
      Joy1YCenter = 512;
      Joy2XCenter = 512;
      Joy2YCenter = 512;
      Joy3XCenter = 512;
      Joy4XCenter = 512;
      Joy1XLow = 0;
      Joy1XHigh = 1023;
      Joy1YLow = 0;
      Joy1YHigh = 1023;
      Joy2XLow = 0;
      Joy2XHigh = 1023;
      Joy2YLow = 0;
      Joy2YHigh = 1023;
      Joy3XLow = 0;
      Joy3XHigh = 1023;
      Joy4XLow = 0;
      Joy4XHigh = 1023;
    delay(2000);
    oled.clear();
    recData();
    if(millis() - lastLoopMillis >= 20){
      lastLoopMillis = millis();
      readInputs();
      setspeed();
      measureVoltage();
      Screen();
      timeout();
    if(millis() - lastSend >= sendDelay || SEND){
      SendData();
R1racing
by R1racing on Wed Jun 12, 2019 5:13 pm
  void setspeed(){
    if(Display <2){
      if(rBut1 == 0 && rBut1State == 0){
        rBut1State = 1;
      }else if(rBut1 == 1 && rBut1State == 1){
        rBut1State = 0;
        if(Speed == 0){
          Speed = 1;
        }else if(Speed == 1){
          Speed = 2;
        }else if(Speed == 2){
          Speed = 0;
        updateScreen = 1;
  void measureVoltage(){
    if((millis() - lastReading >= 10000 && analogRead(battPin) > 1) || startup == 1){
      lastReading = millis();
      measuredvbat = analogRead(battPin);
      measuredvbat *= 2;    // we divided by 2, so multiply back
      measuredvbat *= 3.3;  // Multiply by 3.3V, our reference voltage
      measuredvbat /= 1024; // convert to voltage
        if(startup == 1){
          startup = 0;
  void readInputs(){
    #ifdef serialSound
      lBut1 = digitalRead(lBut1PIN);
      lBut2 = digitalRead(lBut2PIN);
      rBut3 = digitalRead(lBut3PIN);
      if(analogRead(rBut3PIN) > 1){
        rBut3 = 1;
      }else{
        rBut3 = 0;
      if((lBut1 == 0 || rBut3 == 0) && But1State == 0){
        But1State = 1;
        But1Millis = millis();
      }else if(lBut1 == 1 && rBut3 == 1 && But1State == 1){
        But1State = 0;
        But1Sound ++;
          if(But1Sound > 6){
            But1Sound -= 6;
      if(But1Sound > 0 && millis() - But1Millis >= 800){
        voiceSend = 0;
        But1Sound = 0;
        sendToBody.lBut1 = But1Sound;
      }else if(But1Sound > 0 && millis() - But1Millis >= 400){
      if(lBut2 == 0 && But2State == 0){
        But2State = 1;
        But2Millis = millis();
      }else if(lBut2 == 1 && But2State == 1){
        But2State = 0;
        But2Sound ++;
          if(But2Sound > 6){
            But2Sound -= 6;
      if(But2Sound > 0 && millis() - But2Millis >= 800){
        musicSend = 0;
        But2Sound = 0;
        sendToBody.lBut2 = But2Sound;
      }else if(But2Sound > 0 && millis() - But2Millis >= 400){
      if(sendToBody.rBut3 != 0){
        sendToBody.rBut3 = 0;
     #else
      lBut1Timer = digitalRead(lBut1PIN);
      lBut2Timer = digitalRead(lBut2PIN);
        rBut3Timer = 1;
      }else{
        rBut3Timer = 0;
      if(lBut1Timer == 0 && lBut1 == 1){
        lBut1 = 0;
        lBut1Millis = millis();
      }else if(lBut1Timer == 1 && lBut1 == 0){
        if(millis() - lBut1Millis >= 300){
          lBut1 = 1;
      if(lBut2Timer == 0 && lBut2 == 1){
        lBut2 = 0;
        lBut2Millis = millis();
      }else if(lBut2Timer == 1 && lBut2 == 0){
        if(millis() - lBut2Millis >= 300){
          lBut2 = 1;
      if(rBut3Timer == 0 && rBut3 == 1){
        rBut3 = 0;
        rBut3Millis = millis();
      }else if(rBut3Timer == 1 && rBut3 == 0){
        if(millis() - rBut3Millis >= 300){
          rBut3 = 1;
    #endif
    lBut3 = digitalRead(lBut3PIN);
    rBut1 = digitalRead(rBut1PIN);
    rBut2 = digitalRead(rBut2PIN);
    Joy1Xa = analogRead(Joy1XPIN);
    Joy1Ya = analogRead(Joy1YPIN);
    Joy2Xa = analogRead(Joy2XPIN);
    Joy2Ya = analogRead(Joy2YPIN);
    Joy3Xa = analogRead(Joy3XPIN);
    Joy4Xa = analogRead(Joy4XPIN);
    lJoySelect = digitalRead(lJoySelectPIN);
    rJoySelect = digitalRead(rJoySelectPIN);
    motorEnable = digitalRead(enablePIN);
    centerChannels();
    setServoMode();
  void centerChannels(){
    if (Joy1Xa == Joy1XCenter){
      Joy1Xb = 256;
    }else if (Joy1Xa > Joy1XCenter){
      Joy1Xb = map(Joy1Xa, Joy1XCenter, Joy1XHigh, 255, 0);
    }else if (Joy1Xa < Joy1XCenter){
      Joy1Xb = map(Joy1Xa, Joy1XLow, Joy1XCenter, 512, 257);
    if (Joy1Ya == Joy1YCenter){
      Joy1Yb = 256;
    }else if (Joy1Ya > Joy1YCenter){
      Joy1Yb = map(Joy1Ya, Joy1YCenter, Joy1YHigh, 255, 0);
    }else if (Joy1Ya < Joy1YCenter){
      Joy1Yb = map(Joy1Ya, Joy1YLow, Joy1YCenter, 512, 257);
    if (Joy2Xa == Joy2XCenter){
      Joy2Xb = 256;
    }else if (Joy2Xa > Joy2XCenter){
      Joy2Xb = map(Joy2Xa, Joy2XCenter, Joy2XHigh, 255, 0);
    }else if (Joy2Xa < Joy2XCenter){
      Joy2Xb = map(Joy2Xa, Joy2XLow, Joy2XCenter, 512, 257);
    if (Joy2Ya == Joy2YCenter){
      Joy2Yb = 256;
    }else if (Joy2Ya > Joy2YCenter){
      Joy2Yb = map(Joy2Ya, Joy2YCenter, Joy2YHigh, 255, 0);
    }else if (Joy2Ya < Joy2YCenter){
      Joy2Yb = map(Joy2Ya, Joy2YLow, Joy2YCenter, 512, 257);
    if (Joy3Xa == Joy3XCenter){
      Joy3Xb = 256;
    }else if (Joy3Xa > Joy3XCenter){
      Joy3Xb = map(Joy3Xa, Joy3XCenter, Joy3XHigh, 255, 0);
    }else if (Joy3Xa < Joy3XCenter){
      Joy3Xb = map(Joy3Xa, Joy3XLow, Joy3XCenter, 512, 257);
    if (Joy4Xa == Joy4XCenter){
      Joy4Xb = 256;
    }else if (Joy4Xa > Joy4XCenter){
      Joy4Xb = map(Joy4Xa, Joy4XCenter, Joy4XHigh, 255, 0);
    }else if (Joy4Xa < Joy4XCenter){
      Joy4Xb = map(Joy4Xa, Joy4XLow, Joy4XCenter, 512, 257);
    Joy1X = constrain(Joy1Xb,0,512);
    Joy1Y = constrain(Joy1Yb,0,512);
    Joy2X = constrain(Joy2Xb,0,512);
    Joy2Y = constrain(Joy2Yb,0,512);
    Joy3X = constrain(Joy3Xb,0,512);
    Joy4X = constrain(Joy4Xb,0,512);
    if(Display < 2){
      reverseControls();
  void reverseControls(){
    if(Display == 0){
      if(rJoySelect == 0 && JoySelectState == 0){
        JoySelectState = 1;
      }else if (rJoySelect == 1 && JoySelectState != 0){
        JoySelectState = 0;
          if(Fwd == 0){
            Fwd = 1;
            updateScreen = 1;
          }else if(Fwd == 1){
            Fwd = 0;
            updateScreen = 1;
  void setDomeDirection(){
    switch (dome180) {
      case 0:
       if (Fwd == 0){
        DomeDirection = 0;
       }else{
        DomeDirection = 1;
      break;
      case 1:
       if (Fwd == 0){
        DomeDirection = 1;
       }else{
        DomeDirection = 0;
      break;
  void SendData(){
    if(millis() > 2000){
      if(millis() - lastSend >= sendDelay){
        #ifndef serialSound
          sendToBody.lBut1 = lBut1; //left 1
          sendToBody.lBut2 = lBut2; //left 2
          sendToBody.rBut3 = rBut3; //right 3
        #endif
        sendToBody.Joy1Y = Joy1Y; //main drive
        sendToBody.Joy1X = Joy1X; //tilt / steer
        sendToBody.Joy2Y = Joy2Y; //head tilt
        sendToBody.Joy2X = Joy2X; //head spin
        sendToBody.Joy3X = Joy3X; //spin Flywheel
        sendToBody.Joy4X = Joy4X;
        sendToBody.ServoMode = ServoMode; //Select on left joystick
        sendToBody.lBut3 = lBut3; //left3
        sendToBody.Fwd = Fwd; //Select on right joystick = rJoySelect
        sendToBody.Speed = Speed;
        sendToBody.rBut2 = rBut2; //right 2
        sendToBody.motorEnable = motorEnable; //toggle on top
        sendToBody.wireless = bodyWireless;
        memcpy(packet, &sendToBody, sizeof(sendToBody)); //Copy data from "sendToBody" array to "send_buf" byte array
        radio.send(BODY_ADDRESS, packet, sizeof(packet)); //target node Id, message as string or byte array, message length
        delay(5);
        lastSend = millis();
        #ifdef debug
          debugRoutine();
        #endif
    void recData(){
      if(millis() - lastrecDataMillis >= recDelay){
        if (radio.receiveDone()) {
          if(radio.SENDERID == uint8_t(DOME_ADDRESS)){ //********** This needs to be fixed for new lib
            if(radio.DATALEN != sizeof(recFromDome)){
              Serial.print("Invalid DOME payload received, not matching Payload struct! Should Be:");
              Serial.print(sizeof(recFromDome)); Serial.print(" received:"); Serial.println(radio.DATALEN);
            }else{
                recFromDome = *(recDomeData*)radio.DATA;
                //Serial.println(millis() - lastrecdata);
                lastrecdata = millis();
                lastrecDataMillis = millis();
                if(bodyWireless == 0){
                  bodyWireless = 1;
            SEND = true;
          }else if(radio.SENDERID == uint8_t(BODY_ADDRESS)){ //********** This needs to be fixed for new lib
            if(radio.DATALEN != sizeof(recFromBody)){
              Serial.print("Invalid BODY payload received, not matching Payload struct! Should Be:");
              Serial.print(sizeof(recFromBody)); Serial.print(" received:"); Serial.println(radio.DATALEN);
            }else{
                recFromBody = *(recBodyData*)radio.DATA;
                recFromDome.bodyBatt = recFromBody.bodyBatt;
                Serial.println("rec body");
                if(recFromDome.domeBatt != 99.99){
                  recFromDome.domeBatt = 99.99;
                if(bodyWireless == 1){
                  bodyWireless = 0;
            SEND = true;
   void Screen(){
    if(Display < 2){
        infoScreen();
        menuTimer();
    }else if(Display == 2){
      if(ServoMode != 0){
        ServoMode = 0;
      menuScreen();
      MenuTimeout();
      enable = 1;
      Joy1Xa = Joy1XCenter;
      Joy1Ya = Joy1YCenter;
      Joy2Xa = Joy2XCenter;
      Joy2Ya = Joy1YCenter;
      Joy3Xa = Joy3XCenter;
      Joy4Xa = Joy4XCenter;
      lJoySelect = 1;
      rJoySelect = 1;
    }else if(Display == 3){
      domeReverseScreen();
    }else if(Display == 4){
      domeConfig();
    }else if(Display == 5){
      bodyConfig();
    }else if(Display == 6){
      joystickConfig();
      enable = 1;
      lJoySelect = 1;
      rJoySelect = 1;
  void menuTimer(){
    if(rBut2 == 0 && rBut3 == 0 && Display == 0){
      buttonTimer = millis();
      Display = 1;
    }else if(rBut2 == 0 && rBut3 == 0 && Display == 1 && millis() - buttonTimer >= 1500){
      oled.clear();
      Display = 2;
      menuTimeout = millis();
    }else if(rBut2 == 1 || rBut3 == 1 && Display == 1){
      Display = 0;
  void MenuTimeout(){
    if(millis() - menuTimeout >= 15000){
      resetMenu();
  void menuScreen(){
    menuCursor();
    if(casenum != lastcasenum){
      lastcasenum = casenum;
      switch (casenum){
        case 0:
          oled.setCursor(0,0);
          oled.print(">");
          oled.setCursor(15,0);
          oled.println(menuItems[0]);
          oled.print("   ");
          oled.setCursor(15,20);
          oled.println(menuItems[1]);
          oled.print("   ");
          oled.setCursor(15,40);
          oled.println(menuItems[2]);
          oled.print("   ");
          oled.setCursor(15,60);
          oled.println(menuItems[3]);
        break;
        case 1:
          oled.print("   ");
          oled.print(">");
          oled.print("   ");
          oled.print("   ");
        break;
        case 2:
          oled.print("   ");
          oled.print("   ");
          oled.print(">");
          oled.print("   ");
        break;
        case 3:
          oled.print("   ");
          oled.print("   ");
          oled.print("   ");
          oled.print(">");
        break;
    if(digitalRead(lJoySelectPIN) == 0 ||digitalRead(rJoySelectPIN) == 0){
      switch(casenum){
        case 0:
          Display = 3;
          subMenuDome180();
            //Do This to reverse the dome
        break;
        case 1:
          JoySelectState = 1;
          Display = 4;
          oled.clear();
          oled.println("1. Face dome forward");
          oled.println("2. Press 'select'");
          domeConfigTimeout = millis();
            //Do This for Dome Config
        break;
        case 2:
          Display = 5;
          oled.clear();
            //Do This for Body Config
        break;
        case 3:
          Display = 6;
        break;
  void menuCursor(){
    if((analogRead(Joy1YPIN) < 200 && cursorMove == 0) || (analogRead(Joy2YPIN) < 200 && cursorMove == 0)){
      casenum++;
      cursorMove = 1;
      if(casenum > 3){
        casenum = 0;
    }else if((analogRead(Joy1YPIN) > 823 || analogRead(Joy2YPIN) > 823) && cursorMove == 0){
      casenum--;
      cursorMove = 1;
      if(casenum < 0){
        casenum = 3;
    }else if(analogRead(Joy1YPIN) < 612 && analogRead(Joy1YPIN) > 412 && analogRead(Joy2YPIN) < 612 && analogRead(Joy2YPIN) > 412){
      cursorMove = 0;
  void infoScreen(){
    if(millis() - lastScreenUpdate >= 10000 || updateScreen == 1){
      updateScreen = 0;
      oled.print(speedDisplay[Speed]);oled.print(F("        "));
      oled.setCursor(100,0);
      if(Fwd == 0 || Fwd == 2){
        oled.println(F("Fwd     "));
      }else{
        oled.println(F("Rev     "));
      oled.print(F("Body: "));
        if(wireless == 1 && recFromDome.bodyBatt != 99.99){
          oled.print(recFromDome.bodyBatt); oled.println(F("v                 "));
        }else{
          oled.println(F("Disconnected              "));
      oled.print(F("Dome: "));
        if(wireless == 1 && recFromDome.domeBatt != 99.99){
          oled.print(recFromDome.domeBatt); oled.println("v                 ");
        }else{
      oled.print("Remote: "); oled.print(measuredvbat); oled.println(F("v               "));
      lastScreenUpdate = millis();
  void subMenuDome180(){
    if(dome180 == 0){
      dome180 = 2;
     }else{
      dome180 = 0;
    oled.clear();
    oled.print(F("Dome Reversed!"));
  void domeConfig(){
    if(JoySelectState == 1 && sendToBody.CalibID == 0){
      if(lJoySelect == 1 && rJoySelect == 1){
        JoySelectState = 0;
    if((lJoySelect == 0 || rJoySelect == 0) && JoySelectState != 1){
      JoySelectState = 1;
      sendToBody.CalibID = 1;
      oled.clear();
      oled.print(F(" Dome Configured! "));
      domeConfigTimeout = millis() - 8500 ;
    if(millis() - domeConfigTimeout >= 10000){
      JoySelectState = 0;
      resetMenu();
  void bodyConfig(){
    if(bodyConfigStep == 0){
      oled.print(F(" Body Configuration "));
      bodyConfigStep = 1;
      bodyConfigMillis = millis();
      sendToBody.CalibID = 2;
    }else if(bodyConfigStep == 1 && millis() - bodyConfigMillis >= 1500){
      oled.println(F(" Adjust dome tilt        "));
      oled.println(F(" until the dome is        "));
      oled.println(F(" centered front to back.        "));
      oled.println(F(" Then press 'Select'        "));
      bodyConfigStep = 2;
    }else if(bodyConfigStep == 2){
      if((digitalRead(lJoySelectPIN) == 0 || digitalRead(rJoySelectPIN) == 0) && JoySelectState == 0){
        JoySelectState = 1;
      }else if((digitalRead(lJoySelectPIN) == 1 && digitalRead(rJoySelectPIN) == 1) && JoySelectState == 1){
        JoySelectState = 0;
        sendToBody.CalibID = 3;
        bodyConfigStep = 3;
        oled.clear();
        oled.println(F(" Dome tilt offset "));
        oled.println(F(" and pitch offset "));
        oled.println(F(" saved to eeprom "));
    }else if(bodyConfigStep == 3 && millis() - bodyConfigMillis >= 2500){
      oled.clear();
      oled.println(F(" Adjust Side to Side "));
      oled.print(F(" until ")); oled.print(F(droidName)); oled.println(F(" is straight."));
      bodyConfigStep = 4;
    }else if(bodyConfigStep == 4){
        JoySelectState = 1;
        JoySelectState = 0;
        sendToBody.CalibID = 4;
        bodyConfigStep = 5;
        oled.clear();
        oled.println(F(" Body Calibration ")); oled.println(F(" Complete! "));
    }else if(bodyConfigStep == 5 && millis() - bodyConfigMillis >= 2500){
      resetMenu();
  void joystickConfig(){
    if(joyConfStep == 1){
      joyConfMillis = millis();
      joyConfStep = 2;
      oled.clear();
    }else if(joyConfStep == 2 && millis() - joyConfMillis >= joyConfCountdown && waitTime > 0 ){;
      oled.println(F("Release Joysticks"));
      oled.print(F("Wait: ")); oled.print(waitTime);
      joyConfCountdown += 1000;
      waitTime--;
    }else if(joyConfStep == 2 && waitTime == 0 && millis() - joyConfMillis >= joyConfCountdown){
      joyConfStep = 3;
      joyConfCountdown += 2000;
      oled.println(F("Storing Center values"));
      oled.print(F("                    "));
      setJoystickCenter();
      waitTime = 15;
    }else if(joyConfStep == 3 && millis() - joyConfMillis >= joyConfCountdown && waitTime > 0){
      oled.println(F("Continuously rotate      ")); oled.println(F("all joysticks"));
      oled.print(waitTime);oled.print("                  ");
      waitTime--;
    }else if(joyConfStep == 3 && waitTime != 0){
      readJoystickHighAndLow();
    }else if(joyConfStep == 3 && waitTime == 0){
      joyConfStep = 4;
      joyConfCountdown += 2500;
      oled.println(F("Calibration Complete!              "));
      oled.println(F("                                   "));
      setJoystickHighAndLow();
    }else if(joyConfStep == 4 && millis() - joyConfMillis >= joyConfCountdown){
      resetMenu();
  void resetMenu(){
    oled.clear();
    joyConfStep = 1;
    casenum = 0;
    lastcasenum = 1;
    menuConfirm = 0;
    joyConfCountdown = 0;
    waitTime = 5;
    Display = 0;
    sendToBody.CalibID = 0;
    bodyConfigStep = 0;
  void readJoystickHighAndLow(){
    if(start == 0){
      start = 1;
      Joy1XLow = 512;
      Joy1XHigh = 512;
      Joy1YLow = 512;
      Joy1YHigh = 512;
      Joy2XLow = 512;
      Joy2XHigh = 512;
      Joy2YLow = 512;
      Joy2YHigh = 512;
      Joy3XLow = 512;
      Joy3XHigh = 512;
      Joy4XLow = 512;
      Joy4XHigh = 512;
    }else if(start == 1){
      constrain(joyconfigX1 = analogRead(Joy1XPIN),0,1023);
      constrain(joyconfigY1 = analogRead(Joy1YPIN),0,1023);
      constrain(joyconfigX2 = analogRead(Joy2XPIN),0,1023);
      constrain(joyconfigY2 = analogRead(Joy2YPIN),0,1023);
      constrain(joyconfigX3 = analogRead(Joy3XPIN),0,1023);
      constrain(joyconfigX4 = analogRead(Joy4XPIN),0,1023);
      if (joyconfigX1 < Joy1XLow){
        Joy1XLow = joyconfigX1;
      if (joyconfigY1 < Joy1YLow){
        Joy1YLow = joyconfigY1;
      if (joyconfigX2 < Joy2XLow){
        Joy2XLow = joyconfigX2;
      if (joyconfigY2 < Joy2YLow){
        Joy2YLow = joyconfigY2;
      if (joyconfigX3 < Joy3XLow){
        Joy3XLow = joyconfigX3;
      if (joyconfigX4 < Joy4XLow){
        Joy4XLow = joyconfigX4;
      if (joyconfigX1 > Joy1XHigh){
        Joy1XHigh = joyconfigX1;
      if (joyconfigY1 > Joy1YHigh){
        Joy1YHigh = joyconfigY1;
      if (joyconfigX2 > Joy2XHigh){
        Joy2XHigh = joyconfigX2;
      if (joyconfigY2 > Joy2YHigh){
        Joy2YHigh = joyconfigY2;
      if (joyconfigX3 > Joy3XHigh){
        Joy3XHigh = joyconfigX3;
      if (joyconfigX4 > Joy4XHigh){
        Joy4XHigh = joyconfigX4;
   void setJoystickCenter(){
    start = 0;
    EEPROM.writeInt(0,analogRead(Joy1XPIN));
    EEPROM.writeInt(2,analogRead(Joy1YPIN));
    EEPROM.writeInt(4,analogRead(Joy2XPIN));
    EEPROM.writeInt(6,analogRead(Joy2YPIN));
    EEPROM.writeInt(8,analogRead(Joy3XPIN));
    EEPROM.writeInt(10,analogRead(Joy4XPIN));
    delay(1000);
  void setJoystickHighAndLow(){
    EEPROM.writeInt(12,Joy1XLow);
    EEPROM.writeInt(14,Joy1XHigh);
    EEPROM.writeInt(16,Joy1YLow);
    EEPROM.writeInt(18,Joy1YHigh);
    EEPROM.writeInt(20,Joy2XLow);
    EEPROM.writeInt(22,Joy2XHigh);
    EEPROM.writeInt(24,Joy2YLow);
    EEPROM.writeInt(26,Joy2YHigh);
    EEPROM.writeInt(28,Joy3XLow);
    EEPROM.writeInt(30,Joy3XHigh);
    EEPROM.writeInt(32,Joy4XLow);
    EEPROM.writeInt(34,Joy4XHigh);
    EEPROM.writeInt(36,eepromSet);
    delay(1000);
  void domeReverseScreen(){
    if(millis() - menuTimeout >= 1500){
     resetMenu();
  void timeout(){
    if(millis() - lastrecdata >= 2500){
      if(wireless == 1){
        wireless = 0;
        updateScreen = 1;
    }else if(millis() - lastrecdata <= 1000 && wireless == 0){
      wireless = 1;
      updateScreen = 1;
  void setServoMode(){
    if(Display == 0){
      if(lJoySelect == 0 && ServoJoySelectState == 0){
        ServoJoySelectState = 1;
      }else if(lJoySelect == 1 && ServoJoySelectState == 1){
        ServoJoySelectState = 0;
        if(ServoMode == 0){
          ServoMode = 1;
        }else{
          ServoMode = 0;
  void debugRoutine(){
        Serial.print(sendToBody.Joy1Y); Serial.print(", ");
        Serial.print(sendToBody.Joy1X); Serial.print(", ");
        Serial.print(sendToBody.Joy2Y); Serial.print(", ");
        Serial.print(sendToBody.Joy2X); Serial.print(", ");
        Serial.print(sendToBody.Joy3X); Serial.print(", ");
        Serial.print(sendToBody.Joy4X); Serial.print(", ");
        Serial.print(sendToBody.ServoMode); Serial.print(", ");
        Serial.print(sendToBody.lBut1); Serial.print(", ");
        Serial.print(sendToBody.lBut2); Serial.print(", ");
        Serial.print(sendToBody.lBut3); Serial.print(", ");
        Serial.print(sendToBody.Fwd); Serial.print(", ");
        Serial.print(sendToBody.Speed); Serial.print(", ");
        Serial.print(sendToBody.rBut2); Serial.print(", ");
        Serial.print(sendToBody.rBut3); Serial.print(", ");
        Serial.print(sendToBody.motorEnable); Serial.print(", ");
        Serial.print(sendToBody.CalibID); Serial.print(", ");
        Serial.println(sendToBody.wireless);
R1racing
