๐ŸŽ„โ›„โ„๏ธ๐ŸŽ It's beginning to look a lot like ADABOX-mas! The next ADABOX from Adafruit ships soon! Get yours now, or give as a gift! ๐ŸŽ„โ›„โ„๏ธ๐ŸŽ
nRF52840 Express RNG
by czuvich on Thu Jun 13, 2019 7:16 pm
Is there a way to generate a uint32_t random number on the nRF52840 Express?
czuvich
Re: nRF52840 Express RNG
by hathach on Wed Jun 19, 2019 11:31 am
you can use hardware random generator with SD api
https://github.com/adafruit/Adafruit_nR ... soc.h#L489
You can check out noridc document for how to use, there is a example here
https://github.com/adafruit/Adafruit_nR ... o/random.c
note this hw rng can generate something like 64 byte random number, since you only need 4-byte number, a simple sd_rand_application_vector_get(&value, 4) should work.
hathach
by czuvich on Wed Jun 19, 2019 5:10 pm
Thanks! For anyone else wanting a full solution using SD. I found the code online at https://git.card10.badge.events.ccc.de/ ... odrandom.c
static uint32_t machine_rng_generate_random_word(void) {
  uint32_t retval = 0;
  uint32_t status;
  do {
    status = sd_rand_application_vector_get((uint8_t *)&retval, 4); // Extract 4 bytes
  } while (status != 0);
  return retval;
static inline int rand30(void) {
  uint32_t val = machine_rng_generate_random_word();
  return (val & 0x3fffffff); // binary mask b00111111111111111111111111111111
static inline int randbelow(int n) {
  return rand30() % n;
czuvich
