Voltage tracking 4x AA batteries on feather
by IoTAll on Tue Jul 09, 2019 10:47 am
Hi!
I would like to power a feather with 4x AA batteries.
I read on your website that the best way is to use the boost buck converter which convert the 3-12V to 5v and to power the feather with the USB output. Is this the best way?
The question I have also is: is there a way to check the voltage level of the 4x AA betteries with the microcontrollers?
Thank you for the help!!
Best regards,
Ken
IoTAll
Re: Voltage tracking 4x AA batteries on feather
by adafruit_support_bill on Tue Jul 09, 2019 11:35 am
You can monitor battery voltage from an analog pin on the Feather. But you will need to use something like a voltage divider to scale the battery voltage down below 3.3v which is the maximum you can measure on the Feather.
Using a 2:1 voltage divider will keep the voltage within range. And you can just multiply the measured voltage by 2 to calculate the actual battery voltage.
by IoTAll on Mon Aug 19, 2019 1:56 pm
Ok clear thank you!
IoTAll
