Huzzah with OLED Wing - Avoid 1 reset on every startup?
by odinsdream on Fri Aug 16, 2019 8:49 pm
I've built a Feather Huzzah with this OLED Featherwing, https://www.adafruit.com/product/2900
Every time I power on the board it doesn't produce any output on the screen until I press the Reset button on the Featherwing. After that it starts up normally.
During programming, when uploading a new file, the board successfully resets without any manual intervention.
Is there something wrong with my code, or a way to fix this so that the board starts up automatically when it receives power?
odinsdream
Re: Huzzah with OLED Wing - Avoid 1 reset on every startup?
by adafruit_support_carter on Mon Aug 19, 2019 12:58 pm
by odinsdream on Mon Aug 19, 2019 2:37 pm
Perfect! I'll give that a try. Thank you!
odinsdream
