Adafruit_SPIFlash Library - Hangs
by bobtrex on Sun Aug 18, 2019 9:34 am
Since the refactoring of the library and incorporation of QSIP flash, I and a number of others are experiencing "hangs" on library calls that do not return. This effects, M4, feathers, Itsybitsy and Grand Central.
I and others have posted to the libraries Git hub repository. Is that the correct thing to do or should we post in the forums? If forums where is best as is is accross hardware and more Arduino than circuit python.
Thanks and Regards.
bobtrex
Re: Adafruit_SPIFlash Library - Hangs
by adafruit_support_carter on Mon Aug 19, 2019 2:28 pm
Yep. Seems like it in this case. Looks like the issue is here:
https://github.com/adafruit/Adafruit_SPIFlash/issues/21
You could also have started here in the forums if you wanted. But this probably would have quickly become an issue for the software library - so the repo issue is the way to go. Keep an eye on that.
