Feather Huzzah Charging Battery
by TopHatRaver on Wed Aug 21, 2019 1:09 pm
I have wired up a Huzzah to some LEDs with a power Switch as noted in these instructions https://learn.adafruit.com/adafruit-huzzah32-esp32-feather/pinouts#power-pins-2-4 but I have a couple of questions:
1) Is there a way of increasing the charge rate to greater than 100mA? I'm using a 2000mAh battery and it takes a long time to charge it.
2) The light always seems to stay on when charging. I expected it to turn off once the battery was full. Is that incorrect?
Appreciate your help!
TIM
Huzzah Wiring.PNG (182.77 KiB) Viewed 82 times
TopHatRaver
Re: Feather Huzzah Charging Battery
by adafruit_support_carter on Tue Aug 27, 2019 1:11 pm
You would have to change the charge rate resistor, which would require some SMT soldering.
It should. Do you have a lower capacity battery you could try to see if does the same thing there?
