DIY LoRaWAN connectivity tester using the Adafruit Feather M
by mbobinger on Thu Aug 22, 2019 8:30 am
Hello Adafruit-Fellows,
I am trying to follow this project here:
https://lorawantester.com/2019/02/16/di ... comment-27
That uses PlatformIO along with Arduino libraries. It's a pretty specific question but has anyone of you used the Wave library already? I can nowhere find a wave.h library that is able to generate PWM signals using following command syntax:
static wave_generator_t* gen;
uint8_t led_fast_blink(uint32_t t) {
    return wave_pwm( t, 200, 50 );
Thank you!
mbobinger
