Powerboost 500c & 2500mah battery not working
by sawyersweetman on Sat Aug 24, 2019 4:28 pm
hello, im trying to use this powerboost 500c with a 2500mah battery.
when i plug the battery into it, NOTHING ( no lights )
when i plug in the mini USB, everything lights up and it works just fine.
its basically just not working with the battery, i have a volt meter and i did test the battery, its working fine.
any help is appreciated thanks
sawyersweetman
Re: Powerboost 500c & 2500mah battery not working
by franklin97355 on Sat Aug 24, 2019 5:05 pm
Have you tested the voltages on the Power Boost when the battery is plugged in? Can you post a picture of it connected to the battery?
franklin97355
by sawyersweetman on Sat Aug 24, 2019 5:07 pm
sawyersweetman
sawyersweetman
by sawyersweetman on Sat Aug 24, 2019 5:18 pm
no voltage on the 5v pin and when i test the voltage right from where the battery plugs into the female plug on the board, it doesnt seem to have proper voltage either.. 252.2 ??
sawyersweetman
