Hi
Trying to update firmware on a Feather 32u4. I find the board in the app and all looks ok until I hit update. Then it starts the process, but soon tries to pair with the phone. I can’t skip the pairing question and if I pair, the process locks. Need to kill the app to get past that.
In order to find it in the app the board can’t be paired.
When using it for BT control of iPhone, iPad, Mac it only works with a fresh connection (forget device and pair again). It’s this issue I’m trying to solve with the firmware update.
Board got an old firmware from 2015. I think it was the second in the list.
Got 3.5.0 Bluefruit app.
Any thoughts?
BR Stefan
Feather 32u4 Firmware update
- adafruit_support_carter
Re: Feather 32u4 Firmware update
Try clearing the cache to see if that helps:
https://learn.adafruit.com/bluefruit-le ... cache-17-4
and then try again.
and then try again.
- Dalaingenjoren
Thanks for the answer. But as stated in the first post, clearing cache/forget device is the only way of getting it to work. Once. Then I have to forget it again and start over.
- adafruit2
hi the bluefruit maintainer is currently away for lunar new year... you could try posting a photo of what you see in the app update process, that could help debug
- Dalaingenjoren
Tried to attach a video, not allowed.
If the device is paired, it shows up in the list of peripherals. Can be chosen, but can’t find any firmware update. Just stands in the search mode and waits.
So, to get further in the process:
Unpair.
Choose the device in the list.
Finds the list of firmware.
Choose the latest.
Hit OK.
Goes into enabling DFU-mode.
Shows Starting for half a second or so.
Then the question for pairing the device pops up.
If left in that state it just starts over and ends up with the same state. Continues to loop that.
BR
Stefan
Unpair.
Choose the latest.
Hit OK.
BR
Stefan
- Attachments
- EF0FEA27-BA27-4541-9D65-087B46C2955C.jpeg (75.58 KiB) Viewed 114 times
- adafruit2
ok thanks - thach will be back next week (after Lunar New Year) and will reply!
- hathach
hi, I have tried to test with my iPhone but couldn't reproduce your issue.
Could you run
1. factory reset example here https://github.com/adafruit/Adafruit_Bl ... ctoryreset
2. Unpair all of Feather Bluefruit 32u4 from your ipad
3. Try again to see if it work out again.
During the DFU, it shouldn't execute a pairing request.
Could you run
- Dalaingenjoren
Sorry, no difference. Still tries to pair in the DFU-mode.
Found one more odd thing. I normally must forget the device twice. The first time nothing happens. Do it again, and it’s forgotten.
(Happens only with this Bluetooth device).
BR
Stefan
BR
Stefan
- hathach
I am out of idea, maybe you would consider to upgrade to our newer nRF52840 board which has more processing power and more features.
