Hello Everyone,
I went and checked with nRF52840 feather express and noticed the bootloader if fairly old (0.2.6) so I tried to use the adafruit-nrfutil.exe steps to update it. Mine fails on unzipping the zip file for the update. Any thoughts on this? I did go down the other path to build my own self contained and still had the same thing happen.
nrf52840 Express Bootloader Update Fail
- gregtronics
- 2021-02-08 10_58_43-Administrator_ Command Prompt.png (15.84 KiB) Viewed 431 times
- mikeysklar
Re: nrf52840 Express Bootloader Update Fail
@gregtronics,
I took a look at the zip file and I think you need to unzip it once. Then you will find a usable .zip file which you can upload with or a UF2 file if you prefer that style of go into bootloader mode and drag and drop.
$ unzip feather_nrf52832_bootloader-0.4.0.zip
Archive: feather_nrf52832_bootloader-0.4.0.zip
inflating: feather_nrf52832_bootloader-0.4.0_s132_6.1.1.hex
extracting: feather_nrf52832_bootloader-0.4.0_s132_6.1.1.zip
inflating: update-feather_nrf52832_bootloader-0.4.0_nosd.uf2
- 2bndy5
I need help with this too. I've tried both dragging-n-dropping the update-feather_nrf52840_express_bootloader-0.5.1_nosd.uf2 file and the board resets to the bootloader (no CIRCUITPY drive). I've also tried using the adafruit-nrfutil CLI program to flash the bootloader from the feather_nrf52840_express_bootloader-0.5.1_s140_6.1.1.zip file, but I get the same result.
I tried skipping the bootloader upgrade, and just upload the latest version of Circuitpython (v6.3.0). However, the uf2 file doesn't seem to finish copying before the board resets. After the reset I get a CIRCUITPY drive, but I cannot open the Serial port. This is happening on windows as well as Ubuntu (I tried both OS because the tutorial page mentions something about Windows having connection issues).
- hathach
You will need existing bootloader at least version 0.4.0 to perform self-update with uf2 file. The easiest way is using the Arduino IDE to burn the bootloader2bndy5 wrote:I need help with this too. I've tried both dragging-n-dropping the update-feather_nrf52840_express_bootloader-0.5.1_nosd.uf2 file and the board resets to the bootloader (no CIRCUITPY drive). I've also tried using the adafruit-nrfutil CLI program to flash the bootloader from the feather_nrf52840_express_bootloader-0.5.1_s140_6.1.1.zip file, but I get the same result.
https://github.com/adafruit/Adafruit_nR ... r-with-dfu
- 2bndy5
I seem to already have the 0.5.0 bootloader. though IIRC this was the version I tried to flash when I first recieved my feather nrf52 express
I tried using the Arduino IDE (in windows) ,and it gave the same output that `adfruit-nrfutil` tool gives. Again after using the "Burn Bootloader" option in Arduino IDE (in windows), the board resets back into bootloader/DFU mode.UF2 Bootloader 0.5.0 lib/nrfx (v2.0.0) lib/tinyusb (0.9.0-22-g7cdeed54) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Model: Adafruit Feather nRF52840 Express
Board-ID: nRF52840-Feather-revD
SoftDevice: S140 version 6.1.1
Date: Apr 4 2021
Worth noting that Arduino IDE also couldn't reset the board into bootloader mode; I had to do that manually.Upgrading target on COM10 with DFU package C:\Users\ytreh\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.22.1\bootloader\feather_nrf52840_express\feather_nrf52840_express_bootloader-0.5.0_s140_6.1.1.zip. Flow control is disabled, Dual bank, Touch 1200
Failed to upgrade target. Error is: Serial port could not be opened on COM10. Reason: Cannot configure port, something went wrong. Original message: OSError(22, 'The semaphore timeout period has expired.', None, 121)
File "dfu\dfu_transport_serial.py", line 99, in open
File "serial\serialwin32.py", line 33, in __init__
File "serial\serialutil.py", line 244, in __init__
File "serial\serialwin32.py", line 80, in open
File "serial\serialwin32.py", line 222, in _reconfigure_port
serial.serialutil.SerialException: Cannot configure port, something went wrong. Original message: OSError(22, 'The semaphore timeout period has expired.', None, 121)
During handling of the above exception, another exception occurred:
File "__main__.py", line 296, in serial
File "dfu\dfu.py", line 226, in dfu_send_images
File "dfu\dfu.py", line 157, in _dfu_send_image
File "dfu\dfu_transport_serial.py", line 101, in open
nordicsemi.exceptions.NordicSemiException: Serial port could not be opened on COM10. Reason: Cannot configure port, something went wrong. Original message: OSError(22, 'The semaphore timeout period has expired.', None, 121)
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
Please upgrade the Bootloader or select correct version in Tools->Bootloader.
- Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
I will try the Arduino IDE's "Burn Bootloader" option in Ubuntu and see if that consequently helps Windows open the Serial port (when Circuitpython is running) afterward... then I'll post my results.Upgrading target on COM11 with DFU package C:\Users\ytreh\AppData\Local\Arduino15\packages\adafruit\hardware\nrf52\0.22.1\bootloader\feather_nrf52840_express\feather_nrf52840_express_bootloader-0.5.0_s140_6.1.1.zip. Flow control is disabled, Dual bank, Touch 1200
Touched serial port COM11
Opened serial port COM11
Starting DFU upgrade of type 3, SoftDevice size: 151016, bootloader size: 39000, application size: 0
Sending DFU start packet
Sending DFU init packet
Sending firmware file
Activating new firmware
Device programmed.
DFU upgrade took 20.85031747817993s
- 2bndy5
ok, I had to use adafruit-nrfutil in ubuntu because the Arduino IDE version I had installed (via `apt`) was limited to only the AVR boards...
Seems I was able to update the bootloader successfully:
but I still can't open the Serial port on Windows to access the REPL; this seems to be not an issue with the bootloader nor Circuitpython, just with windows... BANNEDUF2 Bootloader 0.5.1 lib/nrfx (v2.0.0) lib/tinyusb (0.9.0-22-g7cdeed54) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Date: Jun 2 2021
- mikeysklar
@2bndy5,
Good job getting the latest bootloader installed using adafruit-nrfutil via CLI.
I suspect you can update using the apt installed Ubuntu Arduino IDE, but you would need to install the appropriate Boards package Adafruit nRF52 as described here:
https://learn.adafruit.com/introducing- ... -bsp-setup
One Windows there are a variety of tools to open the serial console to access the REPL. Which utility were you using? We recommend Putty, but Mu should also work.
https://learn.adafruit.com/welcome-to-c ... on-windows
- hathach
which windows version you are on 7 or 10. Maybe it lacks the driver, you could check with the device manager. If it is the case, just download and install adafruit driver it should set everything up.2bndy5 wrote:ok, I had to use adafruit-nrfutil in ubuntu because the Arduino IDE version I had installed (via `apt`) was limited to only the AVR boards...
Seems I was able to update the bootloader successfully:but I still can't open the Serial port on Windows to access the REPL; this seems to be not an issue with the bootloader nor Circuitpython, just with windows... BANNEDUF2 Bootloader 0.5.1 lib/nrfx (v2.0.0) lib/tinyusb (0.9.0-22-g7cdeed54) lib/uf2 (remotes/origin/configupdate-9-gadbb8c7)
Date: Jun 2 2021
