Feather RP2040 + HC-SR04 Ultrasonic Sonar Distance Sensor
imhavoc
Post by imhavoc »
using the sample code from https://learn.adafruit.com/ultrasonic-s ... ce-sensors, I get the following results:
code.py output:
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
0.272
  File "code.py", line 11, in <module>
  File "code.py", line 9, in <module>
  File "adafruit_hcsr04.py", line 144, in distance
  File "adafruit_hcsr04.py", line 159, in _dist_two_wire
AttributeError: 'HCSR04' object has no attribute '_timeout'
I loaded the code on a Isty Bitsy M0, and it works great.
I moved back to the Feather, and moved the echo pin, and got the exact same result.
imhavoc
Re: Feather RP2040 + HC-SR04 Ultrasonic Sonar Distance Senso
Post by imhavoc »
Hooked up a neopixel ring, no problems. Looks like something in the HCSR04 library is not playing nice with the RP2040.
imhavoc
Post by imhavoc »
Downloaded the latest libraries: adafruit-circuitpython-bundle-6.x-mpy-20210329
Still failing. It takes longer to fail, but it still fails.
adafruit_support_carter
Which Feather RP2040 pins are you using for trigger and echo?
imhavoc
Post by imhavoc »
adafruit_support_carter wrote:Which Feather RP2040 pins are you using for trigger and echo?
Pin D5 for trigger,
Pin D6 for echo.
(It occurred to me last night that the Pin 5 on the Itsy Bisy is 5V, which may explain why it's working and the Feather is not. (?))
While the Trig signal can be 3V or 5V, the 'return' Echo signal is 5V logic. For that reason, we include two 10K resistors, use these as a divider to convert the 5V logic level to a safe 2.5V that you can ready with your 3V device.
Are you setting up the voltage divider?
imhavoc
Post by imhavoc »
adafruit_support_carter wrote:Are you setting up the voltage divider?
Yes.
Hmm. I think I'm seeing the same thing. It might be RP2040 related. There' still some issues being worked out for it. Want to open a new issue here?
https://github.com/adafruit/Adafruit_Ci ... R04/issues
imhavoc
Post by imhavoc »
here is a diagram:
Screenshot 2021-03-30 125412.png (155.51 KiB) Viewed 135 times
stocksp
Post by stocksp »
I'm have exactly the same results.
New Feather hardware (running the sample app with a voltage divider on the Echo) ... I get a dozen good reads and then the crash.
"AttributeError: 'HCSR04' object has no attribute '_timeout'"
Which doesn't make any sense (to me!) as the _timeout attribute does exist.
I moved the library source into my code and printed out the value on each loop (0.1)
Reading the discussion above I'm hearing this is a problem with the Feather and NOT the RP2040?
Did I understand correctly? as I see so many examples of the HCSR04 running on the 'naked' Pico.
Don't mind moving off the Feather till this is resolved ... IF this is a Feather problem and not also a RP2040 or CircuitPython issue...
thanks for any guidance!
P:)
stocksp
Post by stocksp »
I updated my CircuitPython from 6 to 7.0 alpha 6 and the Ultrasonic sensor works perfectly!!
oh happy days!
P:)
imhavoc
Post by imhavoc »
stocksp wrote:I updated my CircuitPython from 6 to 7.0 alpha 6 and the Ultrasonic sensor works perfectly!!
oh happy days!
P:)
stocksp, good to know! Thanks for the info.
