Feather OLED 128x64
Feather OLED 128x64
by jaymgrayson on Sun May 09, 2021 8:33 pm
Have purchased and soldered included headers for Feather OLED 128x64. When I try to run the Circuit Python example I get:code.py output:
File "code.py", line 24, in <module>
RuntimeError: No pull up found on SDA or SCL; check your wiring
I think the soldering looks good. Also the reset button works. Any suggestions moving forward would be greatly appreciated!
jaymgrayson
Re: Feather OLED 128x64
by dastels on Sun May 09, 2021 8:46 pm
Very carefully (i.e. in detail) check the soldering on the 3,3v, SDA and SCL pins, on both boards. Ground seems fine since the rest button works. Post a clear photo of both if you want more eyes on it.
dastels
by jaymgrayson on Mon May 10, 2021 12:26 pm
This worked. One of the pins on the RP2040 needed more solder!
jaymgrayson
by dastels on Mon May 10, 2021 1:20 pm
Cool. Have fun!
dastels
