PIOASM
PIOASM
by DickBurke2014 on Tue May 11, 2021 12:53 pm
I have just received my Feather RP2040 and I have a question regarding programming. I have been using CircuitPython on my Raspberry Pi Pico and just assumed that the Feather could be programmed the same way. When I looked at the overview it leads me to believe that I need to use PIOASM. Is this correct? Or is it just an alternative to CircuitPython?
Thank you for any help you might give. Dick Burkhartzmeyer
DickBurke2014
Re: PIOASM
by adafruit_support_carter on Tue May 11, 2021 1:03 pm
You can totally use CircuitPython on the Feather RP2040. General guide info here:
https://learn.adafruit.com/adafruit-feather-rp2040-pico
but it's essentially the same as what you've probably done for the Pico. Grab firmware UF2 from here:
https://circuitpython.org/board/adafrui ... er_rp2040/
put board in bootloader mode, drag UF2 to RPI-RP2 folder. Done.
Where did you see the PIOASM info? That relates to the PIO feature of the RP2040 chip. There's an associated programming language for using it:
https://learn.adafruit.com/intro-to-rp2 ... cuitpython
But that does not replace the CircuitPython firmware.
Re: PIOASM
by DickBurke2014 on Mon May 17, 2021 6:51 pm
I am sorry that it appears that I've ignored your answer, but I never got an email notifying me of the posting. Thank you for taking the time to answer my question, at 74 yo I need the answers as quickly as possible. LOL
thank you, Dick Burkhartzmeyer
DickBurke2014
