Touch Pad Project - Problem with FeatherS2
by dsheeran on Thu May 13, 2021 5:21 pm
I am trying to do the Touch Pad tutorial and am having some trouble doing it with a Feather S2. This is the error I get...
code.py output:
No SD card found: no SD card
File "code.py", line 34, in <module>
File "adafruit_featherwing/tft_featherwing_35.py", line 34, in __init__
File "adafruit_featherwing/tft_featherwing.py", line 67, in __init__
File "adafruit_stmpe610.py", line 281, in __init__
RuntimeError: Failed to find STMPE610! Chip Version 0xffff. If you are using the breakout, verify you are in SPI mode.
Code done running.
Press any key to enter the REPL. Use CTRL-D to reload.
I used the library packages from the 6.x bundle. I kept the circuit python version that comes with the S2 because it never shows up in Windows Explorer when I try to get into boot mode. So I cannot tell what version of Circuit Python came on the Feather. I do have a 8GB newly formatted SD drive in the slot.
Can someone please help me?
dsheeran
Re: Touch Pad Project - Problem with FeatherS2
sdf
dsheeran
by adafruit_support_mike on Fri May 14, 2021 2:08 am
Post a photo showing you hardware and connections and we'll take a look. 800x600 images usually work best.
by dsheeran on Sat May 15, 2021 10:10 am
Here's the pictures you asked for. I'm sending a couple. Please let me know what you think. Thanks.
dsheeran
by adafruit_support_mike on Sat May 15, 2021 7:56 pm
Thank you. The solder joints on the Feather look good.
What are you using as a power source?
by dsheeran on Sun May 16, 2021 7:23 am
My PC since I'm doing development.
dsheeran
